[5th Gen : 08+]: Location of + of braking wire
Hello,
I'm mounting my backup safety system. It needs to connect to a + wire from brake wire. In left taillight I found two connections:
1. The lower is for reverse light + is green and I used it for a backup camera.
2. The higher is a bit confusing because there go daylights LED at the left side, the turning signal and the braking.
I tried to find a diagram but find nothing.
Thanks for a quick reply. Ok, got it. Unfortunately, I don't have a trailer wiring so I think brake pedal would be the only option.
As I see here (diagram for trailer harness) there should be some sort of red wire from brake pedal? Or is it green too? Honestly, I don't really want to go so deep there... The other option is to take it from a gate brake lamp but as I'm planning to locate the head unit near the radio it will take a long wire.
