[5th Gen : 08+]: 2011 dodge grand caravan fuel pump issue
Old May 6, 2020 | 07:16 PM
cponto's Avatar
cponto
Default 2011 dodge grand caravan fuel pump issue
the fuel pump is staying on after the car is turned off. i have had to pull the fuel pump fuse to stop it. what could be causing it to stay on? also nothing else is staying on and does not do it every time but at least every few times it is turned off.
Old May 7, 2020 | 06:20 AM
Isoldmysaturn's Avatar
Isoldmysaturn
Bad fuel pump relay? Try switching it with another of the same type in your fuse panel.
Old May 7, 2020 | 07:51 AM
Mopar340's Avatar
Mopar340
That's an indication that your fuel pump relay is starting to go bad in your TPIM. Chrysler had a recall on 2011-2013 Durango and Grand Cherokee where they put an external relay outside the TPIM which they sold as a kit Mopar CBWPR091AA I think it's now discontinued and no longer available from Chrysler. Your only possible options a new TPIM or auto salvage replacement there's company that sell rebuilt units or you might want to try vertical visions they have a few more options like their bypass relay kit. verticalvisions.com
Old May 11, 2020 | 01:24 AM
master tech's Avatar
master tech
Site Moderator & Tech
The problem is in the tipm module.Recommend a new tipm module and have it program.
Old May 11, 2020 | 10:04 AM
Mopar340's Avatar
Mopar340
New TPIM and having it reprogrammed is certainly a viable option but the most expensive one anywhere from $1200-$1500. Chrysler had a recall for the exact same issue fuel pump relay on 2011-2013 Dodge Durango Jeep Grand Cherokee over half million vehicle worldwide affected unfortunately the Grand Caravan wasn't included in that recall. Chrysler's fix to their problem for the recall was to disable the internal fuel pump relay in the TPIM and install an external fuel pump relay. If there isn't any other issues within the TPIM only the fuel pump relay I wouldn't replace the entire TPIM module one would think what was approved by Chrysler and NHTSA for the recall would certainly be deem as viable fix. Since the Mopar external relay isn't available anymore I would certainly consider the plug and play fuel pump relay by pass kit which uses a mosfet transistor for the switching versus an electromechanical relay for the fuel pump.
