[4th Gen : 01-07]: Removal of driver side rear inner wheel panel
Old Dec 13, 2020 | 06:57 PM
desertman's Avatar
desertman
Default Removal of driver side rear inner wheel panel
On my 2003 Dodge Caravan, I would like to put the shorter (= first) rear bench into the place where usually the longer (= second) rear bench is. However, that is not possible because the shorter bench is actually on its sides - left and right from the hooks that fix it on the bottom - wider than the longer bench. It's just a little bit, but that is enough to make it impossible to get it into the grooves of the cargo space bottom.
I think it would be possible to fix the bench in the back if the driver side rear inner wheel panel could be removed. How is this to be done?
Thanks,
desertman
