Blend door actuator reset
Old Apr 21, 2021 | 11:18 AM
Readwards1175's Avatar
Readwards1175
Default Blend door actuator reset
Hi I had a battery and alternator replaced now my passenger vent only blows heat when ac is on does anyone know how to reset blend door actuator or re calibrate my van is 2015 Dodge Grand Caravan sxt Canadian bought thanks
Old Apr 21, 2021 | 11:23 AM
Welcome to DF! Moving this to the caravan section.
Old Apr 21, 2021 | 03:15 PM
Mopar340's Avatar
Mopar340
This worked for me a couple of weeks ago the passenger side was stuck on hot and i did this following the instructions from this video and it worked everything good now.
Hope this helps.
Old Apr 21, 2021 | 03:25 PM
Readwards1175
Doesn’t seem to work for me
Old Apr 21, 2021 | 03:27 PM
Readwards1175
Actuator must not work anymore
Old Apr 22, 2021 | 06:49 AM
Mopar340's Avatar
Mopar340
Could be that the gears in your blend door actuator are broken and need to be changed out the passenger side blend door actuator is located underneath the glove compartment you have to remove 2 push pin that hold the noise insulation under the glove box the temp blend door actuator will the first one the left of the glove box the lower one the higher one is for the mode selection.
