[5th Gen : 08+]: 2012 Caravan heat & vent system
Old Jul 21, 2021 | 12:54 PM
4 vans's Avatar
4 vans
Default 2012 Caravan heat & vent system
The vent system lost pressure with the fan on high, I figured it was time to change the cabin air filter. When I pulled it out it was FULL of leaves and other nest material. The downstream duct was also full. I think the main intake for the vent system should be protected with a screen so critters could not get in. Where is the main duct for the vent system on the 2012 Caravan? I need to screen it because the engineers didn't.
Old Jul 25, 2021 | 05:38 PM
master tech's Avatar
master tech
Site Moderator & Tech
Intake duct should be under the windshield and the cowl. You need to remove the cowl to see it.
Old Jul 27, 2021 | 06:07 PM
4 vans's Avatar
4 vans
Thank you.
