[4th Gen : 01-07]: Jerking at constant speed 35-38mph
Old Oct 17, 2021 | 09:22 PM
georgi's Avatar
georgi
Default Jerking at constant speed 35-38mph
When driving Dodge caravan 2001, at constant speed 35-38mph, the van starts jerking.
When releasing the pedal for 10sec, everything is back to normal. It makes this from time to time – 0 to 5 times a month.
I checked today the EGR valve – it is OK.
The transmission was rebuilt 6 years ago (40 000mi), fluid was replaced by schedule.
The fuel filter was replaced 35 000ml ago.
I have another issue that might be connected with this one. For 2 years, again, from time to time, the engine shuts off on parking lots, mainly on the reverse. Since then, I have used fuel system cleaners every 6 months, but no change.
No check engine light, no faulty codes.
Any experience?
Old Oct 18, 2021 | 12:00 AM
master tech's Avatar
master tech
Site Moderator & Tech
It is the torque converter causing your shutter or jerking problem. Replace the torque converter and pump and the problem will stop.
Old Oct 18, 2021 | 04:01 PM
georgi's Avatar
georgi
The torque converter is on 40k miles. Do you think already failed? Which pump do you mean?
Old Oct 19, 2021 | 12:43 AM
master tech
Transmission front pump and yes the torque when it goes into lockup that is causing the shutter.
