[5th Gen : 08+]: Oil Pan Gasket or RTV ??
Old Feb 7, 2022 | 04:20 PM
rolfsb's Avatar
rolfsb
Default Oil Pan Gasket or RTV ??
I am replacing my lower Oil Pan on my 2013 Grand Caravan R/T (the drain plug is completely stripped).
I am having trouble determining whether a gasket is necessary or if it is recommended to use RTV.
I have seen conflicting information; and you can buy gaskets from Rock Auto / Amazon; just not sure if you are supposed to per OEM specs.
Anyone actually replace one?
Old Feb 7, 2022 | 10:10 PM
master tech's Avatar
master tech
Site Moderator & Tech
3.6 will use RTV from mopar. Its called 3 bond sealer.
Old Feb 8, 2022 | 11:19 PM
richardyoo's Avatar
richardyoo
I've done it both ways... RTV and gasket.... I much prefer the gasket and I haven't had a leak using one.
Old Mar 5, 2024 | 12:01 PM
Jason Fritz's Avatar
Jason Fritz
Gasket works fine - just DON'T get the rubber gasket ......get the "paper" one from Felpro ....i say "paper" ...its thicker paper /fiber material - rigid , can't bend it ....comes in a bug square cardboard backed package - on Amazon is like 20$
same for transmission pan gaskets - never get the "set" of transmission filter and rubber gasket -- rubber slips away when oil gets on it and starts leaking !!!!
ONY paper gaskets !!!! :-)
