[5th Gen : 08+]: Transaxle/CV boot?
Old Mar 15, 2022 | 01:16 PM
Beavis519's Avatar
Beavis519
Default Transaxle/CV boot?
I have a 2010 Grand Caravan SXT and there is a noise coming from the front left. The best way to describe the noise is it sounds like something rubbing against something else that is ribbed or has ridges. I highly suspect it's the transaxle or CV boot gone bad and has nothing to do with the transmission. While driving, the sound increases as the speed increases but when I shift to neutral the sound remains constant with the speed, NOT RPM...while in neutral I rev the engine and it doesn't change the sound. I have removed the wheel to inspect for anything rubbing or damage and found none. Is my suspicion correct?
Old Mar 22, 2022 | 01:28 AM
master tech's Avatar
master tech
Site Moderator & Tech
So the sound you are hearing doesn't change even if you are stopped and you are rising the RPM. If you are stopped and not rolling, I think you may have a bearing in the transmission going bad. If you don't hear any sounds when stopped. You either have a bad hub bearing, loose axle nut or the loose pinch bolt for the lower ball joint.
Old Mar 22, 2022 | 01:40 AM
Beavis519's Avatar
Beavis519
I had my brother ride along with me, he is an accomplished mechanic. He says it's a bad wheel hub bearing and explained why. Thank you for your reply though...the noise would get louder as the speed increased, but when I put the transmission in neutral at speed the noise remained constant. It had nothing to do with RPM and would slowly decrease as the vehicle slowed. I have a new hub ordered and will be replacing it this week.
Old Mar 22, 2022 | 01:43 AM
master tech
Thats good to hear. If you need to contact me by a message do so. I just retired as a Dodge, Jeep, Chrysler and Fiat tech.
