[5th Gen : 08+]: dtc codes disappear
Old Apr 6, 2022 | 09:05 PM
steven40's Avatar
steven40
Question dtc codes disappear
tcc p-0740
p-0420
just disappear after oreillys used scan tool
repairs done on tcc solenoid replaced trans fluid
new cv axle
new wheel bearing
generic resonator to front of engine
problems harsh shifting its needing a new transmission
cel was on the other day light is off and now codes r gone after scan used the guy said its against company policy to clear codes
this a buy hear pay hear van
what possible issue
2014 dodge grand caravan 137000 miles
donno if dealer will replace since codes r gone or check engine light is off transmission is going to be delivered monday its already ordered
estimate is being sent to dealer for repairs to be done r they still required to fix it since it was ordered
got van on march 25th
Old Apr 11, 2022 | 11:57 PM
master tech's Avatar
master tech
Site Moderator & Tech
Drive the van till the check engine light comes back on Take it to the dealer to pull codes. But do not shut off the engine, because those will be active codes. Once you turn the ignition off they then become stored code and if the engine controller has a problem it will clear the codes.
