[General]: Has anyone switched a V6 from efi to carb?
Old Apr 14, 2022 | 11:35 AM
Mitsuru's Avatar
Mitsuru
Default Has anyone switched a V6 from efi to carb?
Engine is 3301cc V6 from a 1998 Grand Voyager/Caravan UK spec.
Has anyone removed all the electronics & fuel injection systems.
Then fitted distributor & Carb setup.
This is for a few reasons.
1, Curiosity 2, Microchip & sensor manufacturers supply chain & costs down the line. 3, [for the prepers as live near Nuclear power station & airports] EMP going off
Would love to see pictures and info.
Old Apr 14, 2022 | 11:47 PM
master tech's Avatar
master tech
Site Moderator & Tech
No I haven't. But what type of motor would you replace the motor with?
Old Apr 15, 2022 | 09:40 AM
Mitsuru's Avatar
Mitsuru
No replacing the motor but the intake manifold, coilpack, ECU & sensors off. Then replace with compatible Dizzy, Carb etc
Please remember I'm in the UK, so parts availability is drastically different.
Engine is EGA 3301cc V6 from a 1998 Grand Voyager/Caravan UK spec. BUT it's no-longer in a Grand Voyager/Caravan but a 1997 mk1 Neon.
No SKIMM on the car but was on the doner Export spec Grand Voyager/Caravan.
Old Apr 15, 2022 | 09:45 AM
Mitsuru's Avatar
Mitsuru
Plus thought as the EGA V6 engine was in a lot of vehicles over there someone might have used in hotrods or custom conversion
Old Apr 15, 2022 | 07:07 PM
master tech
Maybe check online to see if there are any conversion kits, The only V6 motor that uses a distributor is a 3.0Liter. The 3.3 and 3.8Liters do not. Same thing with the Neon, Doesn't use a distributor. That is in the USA version. I don't know about the UK.
