[4th Gen : 01-07]: 2006 grand caravan brake pad dragging on disc
Old Jul 22, 2022 | 08:40 AM
Bigmiketx's Avatar
Bigmiketx
Default 2006 grand caravan brake pad dragging on disc
After changing rotors and pads the drivers side pad is dragging on rotor but when I press on brake it goes away.First thought was I didn't have that clip on right but checked it and I believe its on there correct.I welcome antibodies ideas and wisdom.Thank you
Old Aug 7, 2022 | 12:15 AM
lxman1's Avatar
lxman1
Site Moderator
A small amount of drag normal with new pads and rotors. It should quickly wear in though after driving a little bit. Did you clean the caliper where the pads slide on it? If it continues to drag, I have seen the rubber hoses collapse on the inside and not let all of the pressure off of the caliper, so the pads don't release all of the way.
Old Oct 20, 2023 | 05:09 PM
crazyj81's Avatar
crazyj81
Mine is a 2006 also and it was doing the same thing. It was the slides that the caliper bolts onto. Take the caliper off, remove the two slide rods from the caliper mounting bracket, clean them and the holes they came out of and apply some new fresh appropriate grease ....after re instaling and driving around a little I re bled drivers side. Now got full pedal and brakes are working good
