[5th Gen : 08+]: Please help with ABS and traction light flashing NO CODE STORED
Old Sep 10, 2022 | 04:07 PM
Dodgenightmare's Avatar
Dodgenightmare
Default Please help with ABS and traction light flashing NO CODE STORED
Hi,
I have a problem on my Dodge Grand Caravan 2012. The ABS light and Traction Light are flashing for 2-5min every time and not staying on. I cannot clearly diagnose the problem and fix it. No codes are stored in the system. The lights just keep on blinking every half hour, sometimes less, and then go off while I am driving. This has been going on over a year. I have good breaks and new rotors. Eveyrthing else works well.
It makes me so frustrated that codes are not stored and dealership I went to has no idea what to do, and charges could be anywhere from $200 - to infinity for just investigation. I can't agree to this policy.
I am a handy guy and can fix stuff. I change oil, brakes and rotors on a car no problem.
Please help with advice what is the best route to fix this problem and if anyone ever came across the same situation I would be forever greatful for your input.
Please view a small video I attached.
Thank you!!
File Type: wmv
Old Sep 12, 2022 | 11:29 PM
master tech's Avatar
master tech
Site Moderator & Tech
Check the sensor and make should they are not loose.. Also when checking codes. Check it with engine still running because by shutting it off it may clear the codes. I would need to know the active codes.
Old Aug 3, 2023 | 05:39 PM
R'sVan's Avatar
R'sVan
Nice description of the problem an the video describes it even better.
I have the exact same problem. Were you able to resolve the issue?
Thank you.
Old Aug 12, 2023 | 06:29 PM
R'sVan's Avatar
R'sVan
Default Abs and stability control lights sporadic flickering
Originally Posted by Dodgenightmare
Hi,
Thank you!!
Ive checked and cleaned all wheel speed sensor connectors. Remove abs control module cleaned internal contacts and main external connector socket.
checked dynamic input of speed signal using snapon code reader. All live readings were consistent even while the problem was occurring. No codes stored.
The problem only occurs when driving over 80-90 kmph and I seen most often on highway driving. It happens almost always on the start of a highway drive an dissapears sometimes for a while.
The problem is exactly as shown in dodgenightmare's video and description. I was hoping if anyone had similar issues and how they were able to resolve.
Thank you.
Old Jul 19, 2024 | 03:20 PM
Vdominato's Avatar
Vdominato
2012 Dodge Grand Carvan; with ABS and traction light flashing NO CODE STORED.. I too have the same issue. Has anyone resolved this issue before i start taking things apart. Victor Dominato vdominato@hotmail.com
Old Jul 23, 2024 | 01:50 AM
R'sVan's Avatar
R'sVan
Default Replaced sensor
it turned out that the left rear wheel speed sensor was faulty. I can’t remember the name of the scan tool I finally used but it was an advanced scanner that was able to read the code properly.
Hope this helps.
Old Jul 18, 2025 | 04:33 PM
dodgeman314's Avatar
dodgeman314
Default Innova 5610
Hope this helps.
im using an innova 5610 and can not access codes but have this exact issue!!
