What is wrong with my 1995 Plymouth Voyager
Old Feb 6, 2023 | 09:27 PM
meesmotors's Avatar
meesmotors
Default What is wrong with my 1995 Plymouth Voyager
The vehicle was runnable when I started, but now it is not. About a year ago I changed the cam position sensor but while I was changing the sensor it broke in the transmission which led to dropping down the transmission. When I put the transmission back on the vehicle was in an non driveable state. I changed the cam crank oxygen temp map sensor. I tested the throttle senor and erg. I tested the spark with high energy test and the spark seemed to be good. I replaced the ecu with a used one and the condition was the same. I replaced the timing chain. I looked at most all the wires in the wiring harness to check for shorts. I checked the fuel pressure. I checked to see if all injectors were firing. I also did some other electrical test but I did not know if I did them right. I do believe it is an electrical problem dealing with ether fuel injector timing spark timing or intermittent weak spark. When I dropped down the transmission I took off the flywheel to check to see if it was bent. Because the transmission was hanging from the flywheel. I did not know if it could be the fly wheel put on wrong or something in the tranny being bent causing the issue. In the video I keep turning the key and it keeps stalling out. It also has a vacuum leak but it runs better that way.
File Type: avi
Old Feb 6, 2023 | 09:35 PM
Well, you are getting spark, and some fuel at least. Is the check engine lite on?
Moving this to the Caravan section for ya. I think that is the dodge equivalent.
Old Feb 6, 2023 | 10:02 PM
meesmotors's Avatar
meesmotors
I do believe the check engine light is on.
