Rear heater core hose
Old Feb 14, 2006 | 06:07 PM
coochiepoo's Avatar
coochiepoo
Default Rear heater core hose
I have a 98 Grand Caravan and recently found out that the rear heater core hoses have eroded away and ruptured. As a result
the entire contents of my radiator leaked out and left me with an overheating engine. I would like to be able to replace these myself and
would like to find out where the hoses connect to inside the engine. I followed the hoses under the car and they end up going into the engine
but I can't figure out where they wind up? Any help?
Thanks
Old Apr 6, 2006 | 01:14 AM
derwood's Avatar
derwood
Default RE: Rear heater core hose
I had the same problem with my 96 in -40 weather. The garage said the only repair was to replace the coolant hose assembly which coincidently was in stock at the dealership.
Old Apr 8, 2006 | 02:56 AM
HUEY420's Avatar
HUEY420
rear heater hose rusting out is a common problem
Old Oct 10, 2006 | 02:35 PM
Paul22939's Avatar
Paul22939
I replaced the lines on my 1996 Voyager in 2003 and now have to do the same on my 2002 Town & Country. At least now the lines are aluminum in place of steel. Still a bit** to replace.
Old Oct 25, 2006 | 12:44 AM
matt074's Avatar
matt074
I have a 2001 Dodge Grand Caravan and I am having the exact same problem. How were you able to fit the new hose into place?? I just cant get it. Someone told me you have to lift the engine. How did you do it??
Thanks A Ton!!
Old Oct 25, 2006 | 01:01 AM
matt074's Avatar
matt074
I just bought the part from the dealership. $155.00 was the price. What a rip off!! And the new one is Aluminum!! Those idiot's finally figured it out. I still cant get it to fit. Any suggestions?
Old Oct 25, 2006 | 10:10 AM
brandoncrone's Avatar
brandoncrone
To replace that hose assembly you have to remove the wiper transmission assembly, and on the 96 - 00 minivans the upper intake plenum has to be removed as well. Oh its a pain alright...the 01 to present minivans only the wiper assembly has to come off.
Old Oct 26, 2006 | 03:06 PM
matt074's Avatar
matt074
thank you for your help!!
Old Oct 28, 2006 | 07:00 PM
matt074's Avatar
matt074
Still having trouble. This is a hard one. Anybody who has done it?? Any other advice?? Thanks!
Old Jul 19, 2007 | 05:00 PM
eduda's Avatar
eduda
Going through this same grief right now on a 2001 Grand Caravan. I've tried every which way to get the old one out. Any wisdom would be greatly appreciated (aside from taking it to the dealership).
