1990 Dodge Grand caravan
Old Apr 6, 2006 | 05:49 PM
mikest34's Avatar
mikest34
Default 1990 Dodge Grand caravan
I have a 1990 model Caravan the tranny will go in drive but will not shift out of first gear.
Any help would be APPRECIATED.
Thanx Mike
Old Apr 10, 2006 | 09:11 PM
MOPAR MANIAC UK's Avatar
MOPAR MANIAC UK
Default RE: 1990 Dodge Grand caravan
What trans is it??
What engine??
What milage??
Chris.
Old Apr 12, 2006 | 03:58 PM
chopper's Avatar
chopper
Try disconnecting the battery for about ten minutes to reset any transmission codes that may have been set.Reconnect the battery and try it out.This will only be a temporary fix but if it helps it might be the speed sensor that sits between the transmission oil cooler lines.The sensor is on the top,front of the transmission and requires a 1 inch wrench or socket to remove,cost about $20 at the dealer,get the newest version.
