98 T&C Rear Heat Stuck
Old Jun 18, 2004 | 08:45 PM
OHLT1's Avatar
OHLT1
Default 98 T&C Rear Heat Stuck
Just recently, my rear AC/Heat decided to get stuck on the heat setting. It has dual climate control and I have played with all versions of the settings to see if it will switch over and it stays on heat. I checked all the cabin fuses and the ones under the hood and they seem fine.
Another intresting point is that it gives out heat through the lower section and is not affected by switching to a cooler setting. No air comes out of the upper a/c ducts.
Any ideas?
Old Aug 25, 2007 | 12:02 AM
1moparman1's Avatar
1moparman1
Default RE: 98 T&C Rear Heat Stuck
I have the same problem. Did you find a fix??
Old Jun 27, 2010 | 03:48 PM
galefamily's Avatar
galefamily
Default 98 Dodge Grand Caravan, heat stuck on
the other day hot air started comming from my vents. The A/C was working fine earlier that day and I think I had just turned off the snowflake because the van was cooled off inside and I just wanted to let the cool air continue to blow. All of a sudden HOT air started blowing from the vents even with the temp slide all the way to the left. It seems like the heat is stuck "0n" and when I turn on the A/C it cools off a little bit as if the A/C was fighting to overcome the heat at the same time? The engine temp is normal and the A/C compressor is working and the lines under the hood are getting cold. Anybody have any ideas on what to do with this problem??
Old Jun 27, 2010 | 06:14 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
If you have a/c gauges, you need to hook them up and post your reading. You may have a plugged H-valve/expansion valve.
Old Jun 28, 2010 | 09:19 AM
Tizzy1's Avatar
Tizzy1
you can also go to the diy section and perform the actuator calibration / diagnosic test and see what you get.
