Speedometer trouble on 2001 Caravan
Old Aug 16, 2009 | 11:04 PM
Peter Jung's Avatar
Peter Jung
Default Trip reset button works great for me!~
My 2001 T&C has alternator pulley clutch problems and has been slipping - allowing my battery to run down - until the starter solinoid only clicks. At this point my speedo quit and was well below 0mph. I followed the idea of the trip button holddown gauge reset, (after recharging the barrery) and all is well once again!
Old Sep 29, 2009 | 09:38 PM
sihui's Avatar
sihui
Originally Posted by GC_Sport
I pushed the trip button and held it for about 10 seconds, don't know whyI did it, but I did. So after holding the trip button for awhile, I saw an error code come up and read error code check, it went through a slew of numbers... (i.e., 6666666666, 777777777, 11111111, EEEEEEEEEE, and 0000000000 to end it off I believe). After all the numbers displayed then the lights lit up and went through a little sequence and then all the sqares lit up around each gear on the shift part of the dash and then all the lights went off. I then turned the ignition on and the spedo needle reset. It bounced back around where it was supposed to shot straight up and then laid back where it supposed to be and is fine. I drove around for awhile to make sure it's working and everything is great!
Worked for me too, thanks a lot!!!
Old Feb 7, 2010 | 03:26 AM
rabtrfld's Avatar
rabtrfld
Default didn't work for me
tried holding the Trip button for at least 10 seconds, with the key removed, or with the key inserted OFF, inserted ON, no results...
2000 GC 1B4GP44G3YB737313
Old Jun 13, 2010 | 02:17 PM
moosie's Avatar
moosie
Smile Speedodometer problems 2001 Caravan
CG Sport thank you It worked like a charm You probably saved me a ton of money. thanks again from Nova Scotia Canada
Old Jun 28, 2010 | 08:45 PM
Nozzlejocky's Avatar
Nozzlejocky
Smile
My bacon has been saved!!!! Talk about an easy fix. I just used this solution on my 2001 GC speedo which quit after replacing my battery and alternator. Bad part was that I was on my way to Canada for a week. Used my GPS for speed, but dreaded taking it back to the shop again for the 3rd time this month. (Just had the intake gaskets replaced, the rear coolant feed lines replaced, and the AC condenser changed to the tune of about $1200.) Thought I'd search a bit here and voila! My hats off to the participants of this forum. Once again, a savior.
Old Sep 6, 2010 | 01:44 PM
mopar123's Avatar
mopar123
No, no, no! Don't replace the cluster or drill holes or pull apart the dash! it's much simpler than that! I just had that same problem start on Sunday for me. The speedometer wasn't working on the way to church and now my wife just reminded me about it again tonight. So I checked out some other sites and noticed people were having problems with the spedo due to the battery and battery acid leaking. So I checked mine right away. I replaced the battery and then checked the spedo, still same problem. The needle was below the little pin and would not go.... so I started looking at the dash and how to take it apart. Well, fortunatley, not that hard! I pushed the trip button and held it for about 10 seconds, don't know whyI did it, but I did. So after holding the trip button for awhile, I saw an error code come up and read error code check, it went through a slew of numbers... (i.e., 6666666666, 777777777, 11111111, EEEEEEEEEE, and 0000000000 to end it off I believe). After all the numbers displayed then the lights lit up and went through a little sequence and then all the sqares lit up around each gear on the shift part of the dash and then all the lights went off. I then turned the ignition on and the spedo needle reset. It bounced back around where it was supposed to shot straight up and then laid back where it supposed to be and is fine. I drove around for awhile to make sure it's working and everything is great!
Soooo, don't tear your dash apart or drill holes! Just replace the battery, make sure to clean the connectors really well as it sounds like these Caravans have an issue with a lot of corrosion on the connectors. That was definitely the case with mine. Cleaned them well, put in WalMart's top of the line battery and then did the reset as explained above. All is well.
thanks a lot!!!!!!!!! it worked to perfection and saved me a lot of trouble and possibly some money. shudder to think how much money some people spend to get this fixed. i'd be curious to see how much the dodge dealer would charge to fix the problem.
it may not work 100% of the time, but i sure worked in my case. thanks a ton again.
Old Oct 27, 2010 | 09:41 PM
codeman73's Avatar
codeman73
Same here. Also tried turning key from off to on 3 times to check codes, and the only thing that displayed was donE. I have a 2002 Grand caravan.
Old Jun 29, 2011 | 09:21 PM
aelsensato's Avatar
aelsensato
My speedometer was working fine. However, I had my AC evaporator replaced and now the speedometer is not working. I did the trip reset but it still did not move. There was only one connector behind the instrument cluster so I don't think I left any wires unplugged. Is there a separate connector specially for the speedometer? I have a 2001 Grand Caravan Sport.
Old Jun 29, 2011 | 11:51 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
The connector behind the cluster could be unplug or not snap to lock.
Old Jun 30, 2011 | 08:23 AM
aelsensato's Avatar
aelsensato
Smile Solved - Thank you Master Tech
Originally Posted by master tech
Welcome to DF
This is exactly what was wrong with it. Even though the plug was in, it was not locked. This explains why I was able to read all the other controls except the speedometer. Thank you very much for your fast and accurate reply!!
