blowing......not
Old Jul 26, 2004 | 11:23 PM
lake films's Avatar
lake films
Default blowing......not
blowing (Post #1)
Hey everyone,
I hope someone can answer my question/problem:
My blower doesn't work on speeds 1-3, but works on 4. Here's what happened, one time I got in, it was blazing hot so I turned the air conditioner on and put the fan right to high. It then went dead, and decided to come back on in about 15 mins. Last week, I shut the van off to go into a store, but forgot to turn the air off and the blower was on either 2 or 3. Well, it hasn't worked since. I replaced the fuse, no dice. Looked under the hood, tapped the fan, still nothing. Actually, I'm not even sure where the blower is! Thanks in advance!
Hot in NY,
Lance
Old Jul 5, 2010 | 04:18 PM
pgillpro's Avatar
pgillpro
having the same issue with my 96 caravan, any luck?
Old Jul 5, 2010 | 04:41 PM
sapporo's Avatar
sapporo
with a multimeter (electrical measuring tool) a wiring diagram and a shop manual you could have a pretty good idea what is wrong.
chances are pretty good its the blower resistor block.
Old Jul 7, 2010 | 12:20 PM
brettj2408's Avatar
brettj2408
my bet is the blower motor resistor. it defaults to high speed when worn.
if your talking the front blower its under/behind the glove box
Old Jul 7, 2010 | 12:41 PM
sapporo's Avatar
sapporo
the resistor block is located behind the glove box??? on a 1996??? I didn't know that a resistance wire could get worn?
Old Jul 7, 2010 | 01:14 PM
brettj2408's Avatar
brettj2408
sorry forgot these had a resistor block
these are at the back of the engine compartment on the passenger side of the vehicle under the wiper module
Old Aug 31, 2010 | 06:11 PM
jenson611's Avatar
jenson611
so is the resistor block the most common cause for it only working on high?
does this also apply to a 1997 GR caravan with the 3.8?
Old Aug 31, 2010 | 06:38 PM
sapporo's Avatar
sapporo
it even applies to my 1965 mustang.
