If you change you oil every 3,000 miles and keep everything in good shape?
Old Dec 8, 2006 | 05:35 PM
Tali4jc777's Avatar
Tali4jc777
Default If you change you oil every 3,000 miles and keep everything in good shape?
If you change you oil every 3,000 miles and keep everything in good shape, Aprox. how many miles can a Dodge Caravan last. How many miles does you Caravan Have?? Has it given you much problems or will you consider purchasing another model in the future?
Old Dec 8, 2006 | 06:55 PM
mazdab2600's Avatar
mazdab2600
Default RE: If you change you oil every 3,000 miles and keep everything in good shape?
99 d c 140000km 3.0L cranberry
only 2 major problems
1 fried the ecm
2 oil pump seal let go
bought it used was a lease return with 62000km
not sure if i would buy another as i may have just got lucky with this one compared to others
the dealer we bought from had 3 to choose(blue/cranberry/green) from and its funny but the 2 others got sold to 1 friend and the other to a friend of his
they both have had lots of problems
strut towers/tranny/electrical/engine/rust through body doors
Old Dec 8, 2006 | 10:29 PM
jlkinney's Avatar
jlkinney
The transmission needs a filter and 4 fresh quarts of oil every 15 to 20 thousand miles. and with the 3.3 it can run a long time.
Old Dec 9, 2006 | 12:30 AM
caravan99's Avatar
caravan99
I bought mine with 92000 and now is 135000 and run without big problems. the only problems that I had was the blower motor resistors, the serpentine belt tensor was bend, it help to break the timing belt. It cost me about $75 using the Haynes manual!!
Old Dec 9, 2006 | 01:22 AM
computerpulse's Avatar
computerpulse
I love my Caravan. It currently has 199,000 on it but from about 134,000 I started putting in a lot of money. Well just last month the transmission went out. But I love my Van so I invested another 4,000.00 it to it. I don't expect too many other things to go wrong. I figure the motor is next but am hoping I can get another 60,000 miles out of it first. I only buy Caravans. They are comfortable and fairly reliable as long as you take care of it.
Old Dec 9, 2006 | 03:46 AM
brandoncrone's Avatar
brandoncrone
Ive worked on vans with 250000 miles on them with the original motor. Have seen the 604 trannies go 175000+ with proper maintenence.
Old Dec 11, 2006 | 06:17 AM
buckeyeboy's Avatar
buckeyeboy
Great question! This is my first Dodge, and overall I am very pleased with the design. I am hoping that it holds together well with some better than average maintenance from me. I have a general belief that, overall, they must hold together well, or else people would not have made them the #1 seller in their class. I also think that there are so many fleet use of these vans, that some of the problems reported are from maintenance neglect, and rental driver abuse. And that has to drive down the resale value of the entire line.
There is always something that I am working on next to improve it. Tomorrow will replace the headlight housings with some that I have picked up on Ebay for fairly cheap ($15), as the original (2001) was showing alot of wear on the top 1/2 inch of the headlight. Keeping an eye on the waterpump, noticed a small leak. The driver's side window stayed down once, and required a tug on the window at the same time you pulled on the switch.
Myself, I am going with an oil change every 5k. Using Valvoline HM and Mobil1 oil filter.
Old Dec 11, 2006 | 09:48 AM
96grandcaravan's Avatar
96grandcaravan
i bought my grand caravan with the 3.3 @ 97,000 miles and that was 5yrs ago and now it has 254,000 miles on it and just lefted me stranded again. but i don't know if it's the altenator or computer?? but i'm hoping that it's a simple fix ..
i use my grand caravan as a regular truck for hauling newspapers almost 7nights a week. and drive about 200 miles a night
i usually have over a ton of papers in my van.. [8D]
Old Dec 11, 2006 | 08:32 PM
SPLCHAMP's Avatar
SPLCHAMP
Mine is a 99 w\110000 on it and other tha the tune up and maintenance only the ac blower had problems. One other thing theradiator went on it and was a huge mess cause the tranny fluid went into the cooling system. Flushed it out about 4 times, replaced the radiator cap and hoses and works just fine.Nothing happened to the tranny.TG
Old Dec 13, 2006 | 05:50 AM
97 3.5 Intrepid's Avatar
97 3.5 Intrepid
Depends on which engine you are talking about. If you are refering to the original Caravans you can get about 60k out of the 2.6L Mitsubishi. The 2.2L or 2.5L NA versions will at least last 125k. The newer 2.4L will probably not last too much longer than 100k without needing some serious repairs.
The 3.0L is potluck. Either you love it and swear by it, or you hate it and swear AT it. I've never seen a 3.0L Mitsubishi that has impressed me yet, but I'm sure there are some good ones out there; otherwise, it wouldn't have a fan base.
The 3.3L/3.8L will last the life of the vehicle from what I have observed. Keep fresh transmission fluid Chrysler ATF+3 or +4 depending on the year in the tranny and it should last around 150,000-200,000 miles if not longer. Minivans in general no matter what brand don't have a very long life with their transmissions.
