ABS light on - '97 Voyager
Old Aug 12, 2004 | 12:31 AM
oppy's Avatar
oppy
Default ABS light on - '97 Voyager
The ABS light has decided to stay on on the wife's '97 Voyager. Is there a test procedure to follow to check to see where the problem is? I was under the mistaken impression that an OBD tester would pull the code, but it didn't work.
I appreciate any help you guys can offer! [sm=smiley20.gif]
Old Aug 13, 2004 | 12:03 AM
Hemi Powered Ram's Avatar
Hemi Powered Ram
Default RE: ABS light on - '97 Voyager
Unfortunately you'll need to get your hands on a scanner like the one used at the dealer.They're several models of scanners
available such as the Snap-On or OTC models and the dealer scanner DRB3. But take note they all need ABS capapility.
I can tell you most of the time the ABS light comes on is due to a defective wheel speed sensor. If you have an ohm meter
handy you can check the resistance at the wheel speed sensor itself by spinning the wheel and reading the resistance.
Old Aug 13, 2004 | 08:32 PM
oppy's Avatar
oppy
Thanks for the reply. I was afraid that was the case.
Do you know what the resistance is supposed to be at the sensors?
Old Aug 14, 2004 | 04:01 AM
Hemi Powered Ram
I'll get you the specs on Monday
