2001 Grand Caravan Sport/Rear wiper problem
Old Feb 1, 2007 | 05:52 PM
LakeFlambeau's Avatar
LakeFlambeau
Junior Member
Default 2001 Grand Caravan Sport/Rear wiper problem
Newbie to the this Forum, so be nice.... I have looked and I can not find anything on this problem.
My rear wiper does not work in either the intermittent or solid on mode. I have checked the fuses and
they seem to be good. One other thing is the rear washer nozzle does not have anything come out of it
when I just push on that button. I have heard that wiper and pump are on seperate motors, so I am not sure
how this ties together, that they both do not work. Suggestions please.
Thanks....
Old Mar 17, 2007 | 09:58 PM
LakeFlambeau
Junior Member
Default RE: 2001 Grand Caravan Sport/Rear wiper problem
I solved this problem. Might help someoneelse down the line. I unhooked the positivebattery cable
from the batteryfor 3 to 4 hours to "reset" the car. Problem went away.
Old Nov 4, 2010 | 02:23 PM
muhammadkhan's Avatar
muhammadkhan
Default rear wiper not working
my dodge caravan 2001 sports rear wiper is not working.
pls suggest either it is motor problem or fuse problem because my wind shield rear pump is working.
thanks.
muhammad khan
Old Nov 4, 2010 | 08:06 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I would ck the fuses first and then ck power and ground at the motor.
Old Nov 5, 2010 | 12:49 PM
muhammadkhan
Default rear wiper fuse and motor
pls let me know where i find rear wiper fuse and also let me know where is rear wiper motor locate.
thanks.
muhammadkhan
Old Nov 5, 2010 | 02:21 PM
Tizzy1's Avatar
Tizzy1
The fuse is in the fuse box under the hood by the battery. It is fuse 11 and is a 20a fuse. The wiper motor is located in the hatch, the rear wiper arm is attached to the motor. Pin one of the motor connector is ground, pin two is power from the fuse 11 and feeds the park switch and pin three could be constant power, pulsed power or no power depending on where the rear wiper switch is moved to.
Old Nov 6, 2010 | 11:37 PM
muhammadkhan
Default heating and cooling fan
i have 2001 dodge caravan sports and problem is that my fan is run only high speed can you pls suggest what is the problem and who to i solve this problem.
thanks.
muhammad khan
Old Nov 7, 2010 | 01:06 AM
master tech
So what happen on the rear wiper problem? And are asking about the heater blower fan?
