Malfunction Indiactor light stays on 2005 Van
Old Feb 19, 2007 | 05:14 PM
spence99's Avatar
spence99
Default Malfunction Indiactor light stays on 2005 Van
Hi, I have a 2005 Dodge Van and the Malfunction Indicator Light stays on all the time. Does anyone know why this happens and what the repair would be?
Old Feb 20, 2007 | 11:26 PM
vipergg's Avatar
vipergg
Default RE: Malfunction Indiactor light stays on 2005 Van
Get the codes by doing the ignition key dance an post here , ignition on,off,on,offf,on then look at the odometer for the codes , it should read them out .
Old Feb 21, 2007 | 01:14 AM
spence99's Avatar
spence99
Hi, the only code I was able to get is this one P0406
Thanks for any help you can provide
Old Mar 29, 2007 | 02:26 AM
obert's Avatar
obert
So did you get that fixed? I just developed the same problem. My simple scanner shows it as "EGR flow sensor A circut input high".
Just wandering if this is more likley wiring or a bad sensor. EGR flow sensor is the cylender shaped object above the alt on an 3.3 V6, right?
Old Jun 15, 2007 | 09:55 PM
Toyfire's Avatar
Toyfire
Did anyone get this fixed? Ive done searches but I cant find any where what it took to correct the problem. Even if you had to go to the dealer let me know. and if you know what they did or not.
Old Jun 16, 2007 | 01:27 AM
master tech's Avatar
master tech
Site Moderator & Tech
I have already repair 4 caravans for EGR code P0406. All 4 got new EGR valves, And they are back order. The of the van were 2005 and 2006.
Old Apr 14, 2008 | 09:09 AM
chuckb's Avatar
chuckb
hi, my 05 caravan has a miss and p0406 code. is it an easy diy if I get a new egr?
Old Apr 14, 2008 | 04:27 PM
obert's Avatar
obert
I thought it looked like an easy repair. I had the wife stop by the dealer to estimate repair, they, for some reason, thought there was something to do with EGR in the fuel tank and it needed to come out. I didnt have time for that myself, so we let them fix it. Turns out the EGR floe sensor is in fact where I thought it was, next to the alt. The "auto-tech" moved the alt, i guess, and thought it was a PITA. There is a bolt that looks hard to get to, but I work on compact construction equipment.... If that guy thought the EGR sensor was hard to get to he'd never make it in the "dirt" world.
Old Apr 14, 2008 | 04:30 PM
obert's Avatar
obert
Master Tech, is it really that bad? I just noticed it looks like you work on these things... (cars?)
Old Apr 15, 2008 | 04:23 PM
chuckb's Avatar
chuckb
I just finished this job and it was somewhat of a pain in the ***. I understand why the above mentioned tech took the alt off, I almost had to too. I had to use a 1/4 inch 10mm socket to fit on the lower bolt of egr and it was a very tight squeeze. I had to piece extensions, swivels and 1/4 to 3/8 reducer together like a puzzle. the 3/8 socket had no chance of fitting on the lower bolt. everything else was pretty easy, but that bottom bolt is in a bad spot(because of alternator).
