Dodge Challenger Forum for the 2008+ Challenger. This includes the SE, SXT, R/T, Shaker, Scat Pack, SRT and Hellcat models.
Fuel pump sealing ring challenger
Old Jul 26, 2021 | 09:24 AM
Rebecca1995's Avatar
Rebecca1995
Default Fuel pump sealing ring challenger
Goodafternoon,
I hope someone can help me out.
I have a dodge challenger 3.6 V6, year 2011. When I fuel the tank compelety up, there is a gas smell. This smell disappears after 50km or so.
The fuel pump has a leaking sealing ring and hose.
The garage I brought the car to told me the only thing they can do is replace the entire fuel pump (+/- 700euros) as they are unable to get those 2 parts seperately.
So, I am looking for those 2 parts and also they need to be shipped to the Netherlands....
Thank you in advance for your reply
Best regards,
Rebecca
Old Jul 26, 2021 | 02:32 PM
Lock ring:
52110282AA
Gasket:
55366298AA
Which oddly enough shows up as an Alpha Romeo part???? How strange. Both are still available from the dealer, I would like to think they would be available in the Netherlands as well.... talk to the local dodge dealer. (is there one???)
Old Jul 27, 2021 | 03:07 AM
Rebecca1995
Hi,
Great, thanks for your reply.
I will order those items.
The local dodge dealer also say they only have the complete fuel pump.
I will let you know how it turns out.
Old Aug 23, 2021 | 05:11 AM
Rebecca1995
Hi,
Just to let you know that I ordered the parts from the US.
They are the correct parts, which is great. Unfortunately it didn't fix the problem. Still a very strong fuel scent when the tank is full.
The garage advises to replace the entire fuel pump now.
Old Aug 23, 2021 | 08:26 AM
Ouch. I would be tempted to put a LITTLE bit of air pressure on the fuel system, and see if you can hear where it is leaking from. Might be the evap system, might be the pump module.... might be a cracked tank.....
Old Aug 31, 2021 | 08:57 AM
Rebecca1995
Goodafternoon,
Well it turns out the plastic part (I am not sure how to put this in english.. ) of the fuel pump is leaking gasoline.
So I am tempted to just replace the entire fuel pump to make sure the problem is solved. The car also has 120.000 miles on it so replacing the part can't hurt.
Could you help me to find the correct article number? (I am trying to find the fuel pump for a little less than the 500 +euros they are asking at the dealer in the Netherlands.. ) Thank you in advance.
Old Aug 31, 2021 | 09:03 AM
I am seeing a couple different styles of pumps, and some of the refer to the 'driver side primary pump'. Do you have more than one pump assembly in the tank?? If so, which one is leaking.
