Dodge Challenger Forum for the 2008+ Challenger. This includes the SE, SXT, R/T, Shaker, Scat Pack, SRT and Hellcat models.
Trickle Charger Use
Old Dec 30, 2025 | 12:09 PM
Hellcatter's Avatar
Hellcatter
Default Trickle Charger Use
I have two cars and two trickle chargers. One battery is fairly new (2.5 years old) and one old (6 years). I typically get out once a week for a drive but now it's winter so I don't get out as often. For the older battery I keep the trickle charger on always, for the newer battery I'll pull the charger if I'm driving once a week. Is it safe to just always keep the trickle chargers attached no matter how often I drive?
Old Dec 30, 2025 | 12:11 PM
Originally Posted by Hellcatter
I have two cars and two trickle chargers. One battery is fairly new (2.5 years old) and one old (6 years). I typically get out once a week for a drive but now it's winter so I don't get out as often. Is it safe to just always keep the trickle chargers attached no matter how often I drive?
I have three tractors that I pull the batteries for the winter months. They are on trickle chargers in the garage for several months. The batteries last a LOT longer that way..... These are smart chargers though, so, they won't overcharge the batteries.
Old Dec 30, 2025 | 12:18 PM
Hellcatter's Avatar
Hellcatter
Thanks, HeyYou! I am all about extending battery life and I only recently started using the charger on the old battery and I absolutely think it's extending the battery's life. So I'll do same for the newer battery.
Old Dec 31, 2025 | 09:51 PM
dodgetruck2's Avatar
dodgetruck2
You need to make sure you have float/maintenance/smart (terminology variations for same thing) which like mentioned, maintains voltage without overcharging, a plain oil trickle or 2amp charger will do this in time if its not designed to cycle accordingly
Old Jan 1, 2026 | 10:26 AM
Hellcatter's Avatar
Hellcatter
Thanks, Dodgetruck2! I pulled out an old Schumacher that does smart maintenance and bought a new Yonhan which does ditto. Both are working real well.
Old Jan 1, 2026 | 11:14 AM
Hellcatter's Avatar
Hellcatter
Update: For the Yonhan, from what I can tell, while it will do a trickle function, it does not go into that mode automatically - which is ridiculous. I'll search for another charger/maintainer.
What I've found (and maybe most people know this) is that most chargers/maintainers need to be manually put into trickle/maint. mode once the battery is full and some need a disconnect/reconnect to work. It seems the entire Schumacher line (from what I can tell) will change from full to maint. automatically. I already had on old 6amp with LED indicators and recently bought the 3amp SP1356 with digital indicators for intervention-free maintenance.
Old Jan 2, 2026 | 01:37 PM
dodgetruck2
Definitely something to watch for, I have a Harley Davidson stickered one for my motor cycle it switches automatically, and it uses teh same 2 pin weether pack as all the other models so i can move it around as need, Ive also picked p a few 10-15$ ones from harvor freight that have worked well as well, I have a beefy Durastart or some brand i picked up at a pawn shop, its a decent sized brick, and it maintains automatically as well
Old Jan 2, 2026 | 07:58 PM
Hellcatter's Avatar
Hellcatter
Right - everyone's application is different. I might drive a car two, three days in a row but might not drive same car for several weeks. The Schumacher (or similar) allows the battery to be at 100% all of the time, extending battery life (so I'm told). Takes literally 20 seconds to hook it up and forget about it. But what I can't do is check on the battery charge level and then once at 100% manually change to trickle.
Old Jan 2, 2026 | 08:51 PM
The cheap harbor fright fellers I have do it all automagically. They will charge the batter to full, then just apply voltage as needed. Work great. Been using them for five or six years now.
Old Jan 3, 2026 | 03:55 AM
Hellcatter's Avatar
Hellcatter
Somehow I forgot about those because we batted the product around here but I did not know that they went to trickle automatically - that's great info to note.
