Sponsored by:
Sponsored by: CARiD
X pipe rattle
Old Apr 16, 2007 | 02:10 PM
BigBananna3796of4000's Avatar
Default X pipe rattle
How do you get the X pipe top stop hitting the cross member over bumps.
I was told to shim it out but what does that mean?
Old Apr 16, 2007 | 04:02 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: X pipe rattle
This thread should help => https://dodgeforum.com/m_574793/tm.htm
Old Apr 17, 2007 | 02:51 PM
It does help thanks.
Exhaustguy said they would adjust and it is not a problem.
Old Apr 17, 2007 | 05:04 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
It shouldn't take them over 15 minutes to put her up on the jack and tweak her.
Old Apr 18, 2007 | 03:03 AM
baldyloxs's Avatar
baldyloxs
I removed mine,now I have ratle on the tank that cant be adjusted.(everything is pushed forward as far as it can be)
The only thing I can think of is chopping an inch of my muffler outlets to move them foward.Any other Ideas out there?
Old Apr 18, 2007 | 10:46 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
It's not often but I get a rattle every now and then like you described,on the tank, and had the same thoughts. I may chop mine a half inch and see if that does the trick.
Old Apr 18, 2007 | 06:09 PM
74scamp's Avatar
74scamp
I just used a couple of thick washers and shimmed the cross member down from the bottom of the undercarriage a bit. No problems here now.
dave
Old Apr 18, 2007 | 08:41 PM
They shimed my cross member too. Took 10 mins. They do really good work and mentioned the mufflers hitting the tank too. They said no fix for it and avoid big holes.
Old Apr 18, 2007 | 08:44 PM
Baldy,
Have you or anyone noticed you get better arond town gas millage w/ the headers? My car read a solid 13.4 miles per gal and since the header install it is now 14.8
I stand on the gas a bunch too and yet my miles per gallon has gotten better.
No CELS yet.
Old Apr 19, 2007 | 11:04 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I didn't notice a drop in MPG with my swap. Also there wasn'ta MPG drop after the cam install.
It'sgreat to add these mods and not suffer from them [sm=smiley20.gif]
