Sponsored by:
Sponsored by: CARiD
Brake Light on Dash
Old May 26, 2007 | 02:31 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default Brake Light on Dash
Has anyone had the red brake light come on while you were driving, and no codes. I have found the fix.
Old May 26, 2007 | 12:08 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Brake Light on Dash
Nope, but it would be gracious of you to post said fix.
Old May 26, 2007 | 12:20 PM
Dodge Tech's Avatar
Dodge Tech
add brake fluid ,replace pads,look for a brake fluid leak.
Old May 26, 2007 | 11:41 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Old May 27, 2007 | 12:46 AM
master tech
I got the information from Star oline ( Chrysler ) The fix is to replace the E-Brake cable, Because the cable that came with the car is 1/8 inch longer. The new cable is 1/8 shorter. The longer cable allows the ratchet to ground the brake lite switch causing the red brake lite to come on and no codes.
