Sponsored by:
Sponsored by: CARiD
Mods and mpgs
Old Aug 22, 2007 | 11:58 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Mods and mpgs
EVIC is usually close but I have noticed that there is something about EVIC where the mileage keeps going down when I’m idling at a stop. I understand the mpg should go down at idle but it seems to end up lowering the EVIC mileage more than it should, about 1.5 to 2 mpg lower than calculated.
I don't know the algorithm they use but they have to go off actual readings from the gas tank, RPM, fule map, tire size, speed and/or additional variables.
Old Aug 22, 2007 | 03:22 PM
Texas Crewd's Avatar
Texas Crewd
I find the same with computer calculated mpg. Generally fairly close when going down the road but completely off in town. If you reset frequently perhaps but combination driving with a heavy foot will leave you walking to the pumps if you really on it.
Old Aug 22, 2007 | 03:33 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
It’s damn near impossible to get a completely accurate mpg.
When I fill the tank I can't tell if the pump cut off at the same place as the previous fill. Temperature, humidity and other factors can cause it to be short or long, so that throws off the manual calculation as well
Old Aug 22, 2007 | 05:08 PM
Texas Crewd
Randall,
I was just checking out your pics. That is one good looking Charger. I love that hood and intake.....saweeet.
Garry
Old Aug 22, 2007 | 06:28 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Thanks Garry, there's a couple of us on this forum that have that RAMAirHood. It sure gets attention whever we go
Old Oct 11, 2007 | 11:39 AM
riannapo's Avatar
riannapo
I stopped doin hand calc's as I have found that the EVIC is almost always the same...within .1 mpg!
Old Oct 11, 2007 | 12:15 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I like having a written log just in case I sell the car.Some people notice detaild log of fule/oil changes as a sign that the car was well maintained.
Old Oct 11, 2007 | 01:38 PM
74scamp's Avatar
74scamp
I'm still getting between 25 - 28 on the highway (75-80). That's what the EVIC says. I reset it from time to time, though. In town, I can play a bit and still get 20+.
Now, I'm at a mile high and I still wonder if the computers make it run leaner at my altitude than you folks closer to sea level, which would make it use less gas.
dave
