Sponsored by:
Sponsored by: CARiD
Got canned
Old Sep 12, 2007 | 10:50 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default Got canned
I had the oil gunk buildup on my intake throttle body butterfly and on down throughout the intake. I also pulled the injectors and the outside of the injectors were coated with the same black oil gunk.
Needless to say I cleaned the gunk out and received/installed a Billet Technology (BT) catch can. It goes between the PCV valve andthe intake and traps oil from getting into the intake.
BT's catch can is very cool in that it installs in under 5 minutes and fits perfectly in the engine compartment. Some have installed it w/braded hose instead of the rubber hose and it really looks sick <= upgrading to braded hoses will be a rainy day project on my list.
[IMG]local://upfiles/33009/9B750EFD619A42EFB95AB16CB40EECD9.jpg[/IMG]
Old Sep 12, 2007 | 06:58 PM
74scamp's Avatar
74scamp
Default RE: Got canned
Wow! I've been out of the loop for a while. Is this a serious thing? OK, that sounds like a stupid question - is it a wide spread problem?
dave
Old Sep 12, 2007 | 09:38 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
It isn't that big of an issue, there's blow by from the PCV valve to the intake. Those that have cams and such get more buildup; you can just clean it now and then or get a catch can.The quantity of oil isn'tthat much, some people noticed when they first started up in the morning a puff of white smoke from the tail pipe which was a little oilburning off.
I noticed the build up some time ago when I was fiddling with the nitrous switch. To set the switch you take the intake off and hold the flap open with your hand to simulate WOT, that's when I saw black gunk on the inside of the flap. Didn't think that much of it at the time Ijustcleaned it off. Recently Iswapped outto 6.1 injectorsand noticed every stinking one had that same resin "black gunk" on them.
Since then there have been several threads that revealed where that build up ofblack gunkwas coming from.
You can make one of these catch cans for $10-15 with parts from your favorite hardware store or you can shop around and get one specifically made for the LX.
Old Sep 13, 2007 | 10:11 AM
charginscott's Avatar
charginscott
I`ve been tossing the catch can around for a while now. I see you`r intake tube is like mine. Homemade? Did you move you AIS sensor twards the filter? Sorry bout the questions.
Scott
Old Sep 13, 2007 | 11:26 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Yes I enteneded it closer to the filter and next is the crank vent and finally the N20 nozzle. I didn't want the N20 spraying on the O2 sensor.
Old Sep 13, 2007 | 01:01 PM
charginscott
Ya that could be bad for the sensor and prolly freak out HAL
Scott
