Sponsored by:
Sponsored by: CARiD
Mod 1,2,3
Old Sep 25, 2007 | 04:50 PM
crapscott's Avatar
crapscott
Default Mod 1,2,3
The first Mod I did was immediately placed a K&N FIPK. Had to wait for the updated Superchip 3825. Programmed that into the car.Then I recently put on the Borla 140122. I pulled the fuses 11,14,16 and rest Hal. I use the turn key to rid ESP. Pulling fuse 17 was not for my car at all.
My questions are:
Should or would it help to reload/reprogram the Superchip now? Will it make a difference?
I was confused about the torque question. Pulling boats for years with a truck, the question about decreasing the torque seams opposite to what the ultimate goal is. How did most ppl program the SC?
Thanks
Scott
Old Sep 25, 2007 | 06:59 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Mod 1,2,3
The option your looking at is reducetorque management not torque.
Torque management influences shift points, throttle position & timing. You may have the car at WOT and the PCM looks at the throttle position, speed and rpms and only allows 70% throttle (<= just an example) the car may feel like it’s falling on its face. This is DCXs brain child called torque management.
Old Sep 26, 2007 | 10:46 AM
crapscott's Avatar
crapscott
Ok I feel like a moron. I understand the words you used. WOT (Wide Open Throttle) and PCM - Power Train Control Module.
When it gives me the option of reducing torque management. What gives me a better hole shot? I ask several ppl some are even ASE 5 mechanics and I get all different answers. The question is confusing to me.
I feel like the SC can give me more even though I do need change the plugs. Now I am told to look at the fly throttle wire.????
Old Sep 26, 2007 | 12:20 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Your no moron, far from it, this is a new environment and it takes a little time to get into the swing of things [sm=smiley20.gif]
Defiantly reduce the TQ mgmt, that way it will not interfere with abnormal driving habits
I haven't seen or found any tweaks for the fly by wire yet. My 03 RAM Hemi had the first DCX fly by wire and there was play in the receivers cable. A person could use a tire wrap to take the slop out of the cable and drastically improve throttle response.
<edit> fly by wire... there isn't a cable going from the gas peddle to the throttle plate. It's electronic and wireless.
Old Sep 26, 2007 | 12:37 PM
crapscott's Avatar
crapscott
Appreciate the assistance. I will get to programming. I was unsure. I was not aware of this forum for the first year of my purchase. I somehow stumbled upon it. It is great. All I know is right now I am having lowRPM response issues. All it might be is that I need to clean some of the crapout of the CAI filter. I just popped the hood toverify the fuse line-up and it has some crap in it.
Nonetheless, thanks for the help. Waiting on the cool weather and I'm sure it will run better and I will reduce the TQ mgmt.
Scott
Old Sep 26, 2007 | 04:02 PM
BigBananna3796of4000's Avatar
I couldnt tell a difference when I played around with the Torque managment so I left it alone.
It actually felt better with out changing any programming.
Did I do something wrong?
Old Sep 28, 2007 | 12:13 AM
srteatr's Avatar
srteatr
I agree with your BigBanana... I am going to test my car in a few days on a dyno and see what the results are from using that Tuner... Its great for changing the speedo and tire sizes. I still have not tested my top speed after setting it to 170. I got to 140 with no problem and ran out of room. I hot the brakes to slow down and it scared me, the stock ones are garbage so I replaced the pads and rotors... Perfect I will try again late one night...
