Sponsored by:
Sponsored by: CARiD
Thermostat ?
Old Oct 29, 2007 | 07:52 PM
733subvet's Avatar
733subvet
Default Thermostat ?
have been looking at a 180 thermostat that everyone on here seems to love but one simple ?
i have seen a 165 thermostat that would seem to offer better performance but is this a smarter move since it would "technically" keep the engine cooler then the 180 ?
Old Oct 30, 2007 | 09:58 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Thermostat ?
It would technically keep the engine cooler but there is a point of diminishing returns, you will get Check Engine Lights (CELs) when you go too low. Go with a 180 and you will be happy any cooler and you might have issues.
Old Nov 4, 2007 | 04:07 PM
Midnight Blue's Avatar
Midnight Blue
Your engine needs to retain some heat to remain at an optimum operating temperature. The we used to call the 165's tropic thermostats. I tried one when I lived in Hawaii and ended up going back to a 180 when I got my radiator recored . I have noticed my 06 has a sweet spot around 195 degrees. A 180 (or maybe 190?) with the correct fan setting should be sufficient. A 165 might make it run too cold on the open road.
Redbeard
Old Nov 4, 2007 | 04:41 PM
IXLR8's Avatar
IXLR8
For me the 180 worked great, no error codes. Since I have not modified my fan control, it only makes a difference on the highway. In stop and go traffic it stays just where DCX programmed it.
Be careful selecting the correct thormstat. The first one I installed was a fraction to deep, and it was mechanically kept from opening because of clearance, causing my engine to overheat. The installation is a snap, if you can locate the video someone made and posted on here.
Enjoy!
Old Nov 4, 2007 | 04:52 PM
733subvet's Avatar
733subvet
i appreciate all the feedback
can you guys suggest the right one to get ? i have the 5.7L with a K&N CAI and flowmaster exhaust. i have 3 different parts stores within 3 miles of me ( PEP BOYS, AUTOZONE & ADVANCED AUTO)
Predator should be here tomorrow - UPS wont deliver without a signature and was away friday & saturday - DAMN
Old Nov 4, 2007 | 05:35 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Engine temps will rise to stock tempature unlessyou have a fan mod or a tuner that allows you to override the stock settings.
Here are a couple 180 t-stats that you should be able to find:
PepBoys - Stant 14248
NAPPA - 191 THM
<edit> I saw a post that said that Autozone has a valuecraft 180 t-stst part number 4128
The key is their 2.5 inch wide (63.5mm).
Old Nov 14, 2007 | 07:42 PM
rucci1's Avatar
rucci1
which 180 degree thermostat is everyone running right now or pleased with? i bought the coolit mod from noesp and have it sitting here on my desk. have never installed it. I installed the noesp mod and forgot about the coolit mod... need to know what thermostat everyone is pleased with.
Old Nov 14, 2007 | 07:49 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Two of the more common ones are in the post above yours, I run the NAPA.
Old Nov 14, 2007 | 08:04 PM
rucci1's Avatar
rucci1
thanks mango haven't been around in a bit.. i appreciate the info. catch you guys later..
