any suggestions for better gas mileage???
does anyone have any suggestions on how to get more miles per gallon on my 07 dodge charger? i just got 22" rims. should i get my cpu reprogramed or something. what else can i do?
Keeping MDS intact and watching your driving habits are the best things you can do for better MPG.
Yes you should modify the tire size paramater in the PCM. You can do this via a tuner like Diablo/Superchips or I'm sure a dealership willmake the changefor some money.
I shouldn’t have put it this way; you can modify the car so MDS doesn't work. You can create a lot of HP and keep MDS, some have chosen to put a non-mds friendly cam in their 5.7 and have disabled MDS. Some have even taken out the MDS solenoids and replace the MDS lifters with standard non MDS lifters.
The way I keep the engine in MDS mode is to use the cruise control as much as I can. This keeps the engine in fuel saver mode as much as possible Also another good way is lift on the gas pedal after desired speed is atained. Hope this helps, plus I use Z-Max 30 micro lubricant. Which you can buy at any Pepboys store.
Im still getting good mileage with MDS off 21 on highway !!!!! would be better if we went on longer drives
Trending Topics
My thoughts on gas mileage, some are cheap and easy others cost a little.
Synthetic oil helps, as will additives like z max. Cold air kit and aftermarket computer help too, but take longer to realize the payback.
keep your tires properly inflated. Finally the most controversial one, slow down the faster you go the more gas you use. Coast more brake less, everytime you step on the brakes you waste gas, yes that's right the brakes, You are robbing the energy you have built up getting the car going and turning it into heat in the brakes. Using all these things my 06 Daytona averaged over 24 mpg on a trip from PA to Las Vegas and back, actually the slow down idea wasn't used much lol. 3 full size adults in the car driving 75 to 80 most of the way, trunk packed. I had several tanks over 27 mpg, this also included 3 days of city driving in Vegas. I found the 91 octane tune on my superchips gave the best mpg, I tried them all on the trip. Sorry for the long post, hope this helps.
