Sponsored by:
Sponsored by: CARiD
2006 dodge charger
Old May 8, 2012 | 05:18 PM
tputnam's Avatar
tputnam
Question 2006 dodge charger
What's going on with my headlights when I turn the car on the headlights come on and stay on even when I turn the headlights switch off. Does anyone know what I can do to solve this problem?
Old May 8, 2012 | 06:06 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
It's called day time running lights or if sometimes referred to as DRL. This is a safety option that is installed/ turned on from the factory.
Old May 9, 2012 | 11:56 AM
DodgeCares's Avatar
DodgeCares
Putnam,
Did this just start happening? If you PM me the VIN I can see if the DRL's were enabled at the factory. If the vehicle was originally sold in Canada then for sure it came from the factory that way as it is the law in Canada that vehicles have DRL's.
Old Jun 14, 2012 | 02:53 PM
tony smith's Avatar
tony smith
help when i turn my headlights on at night my dashboard lights gose off
Old Jun 14, 2012 | 03:02 PM
DodgeCares's Avatar
DodgeCares
Is you interior light control turned all the way up? If it is turned down this will happen. When you turn your headlights on at night next time, turn your interior lights all the way on until the courtesy light comes on inside the vehicle then back it off only enough to turn the courtesy light out. Are the dash lights still off?
Old Jun 14, 2012 | 03:05 PM
tony smith's Avatar
tony smith
no nuttin
DodgeCares's Avatar
DodgeCares
Dimmer Control
The dimmer control is part of the
headlight switch, and is located on the
left side of the instrument panel. With
the parking lights or headlights on,
rotating the dimmer control upward
will increase the brightness of the instrument
panel lights.
Old Jun 14, 2012 | 03:07 PM
tony smith's Avatar
tony smith
i can only see the temp outside and what gear im cant see how fast im goin or how much gas i have
Old Jun 14, 2012 | 03:08 PM
tony smith's Avatar
tony smith
could it be a bad switch or what
Old Jun 14, 2012 | 03:19 PM
DodgeCares's Avatar
DodgeCares
It could be the switch. Do the dash lights work when only the parking lights are on?
