Sponsored by:
Sponsored by: CARiD
2008 Dodge Charger won't start
Old Oct 7, 2012 | 05:51 PM
dvldawg513's Avatar
dvldawg513
Default 2008 Dodge Charger won't start
Recently my Charger quit starting. The battery is good, lights and everything work fine. Remote unlocks doors and opens trunk fine. However, when i put the key (not an actual key, just a little electronic box) into the ignition and turn it nothing happens. That starter doesn't try to turn over, can't take the car out of park. Does anyone know what could be wrong?
Old Oct 7, 2012 | 08:08 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Sounds like your FOB somehow lost its program.
Old Oct 7, 2012 | 10:31 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
If you find that your key IS bad, have the dealer check for the H30 recall. You get 2 sparkling new ones!
Old Oct 8, 2012 | 03:23 PM
DodgeCares's Avatar
DodgeCares
Dawg,
Here is a copy of the recall mentioned above.
Customer Satisfaction Notification H30
Remote Keyless Entry Transmitters
Those vehicles that have already had this repair performed, as determined by our
warranty records, have been excluded from this notification.
2008 (LX) Chrysler 300, Dodge Magnum and Charger
2008 (RT) Dodge Grand Caravan and Chrysler Town & Country
2008 (WK) Jeep Grand Cherokee
2008 (XK) Jeep Commander
NOTE: This notification applies only to the above vehicles built through
October 30, 2007 (MDH 103000).
The Remote Keyless Entry (RKE) transmitters on about 169,800 of the above
vehicles may exhibit poor retention to the valet key and could inadvertently
separate from each other.
Both RKE transmitters must be replaced and the new transmitters must be
programmed.
Old Oct 8, 2012 | 08:39 PM
steak59's Avatar
steak59
do you have a 2nd key to try? Does the Red warning Light on the dash comes on or blink?
I am going to say you have a bad key. Like everyone else said. The Recall is very limited, most cars are not covered. But call ur dealer.
Old Oct 9, 2012 | 01:32 PM
dvldawg513's Avatar
dvldawg513
No 2nd key. It was lost shortly after i got the car. I called my local dodge dealer and they said that my VIN matched the recall, but they need to have the key and the car and that's a problem because the car will not start..... So now i'm gonna have to end up paying to get the car to the dealership
Old Oct 9, 2012 | 04:41 PM
TNtech's Avatar
TNtech
The recall is for this symptom...
...so at least the keys are paid for.
Old Feb 6, 2013 | 02:03 PM
jway's Avatar
jway
Default This is the same thing that is going on with my Charger? Did you find a solution?
By any chance did you find the solution this happened to my car 2 days ago and I NEED HELP PLEASE!!!
Old Feb 6, 2013 | 02:12 PM
jway's Avatar
jway
Default And doubt its the key the red warning light is not on
Help some one any one..........
Old Feb 18, 2013 | 04:15 PM
Bubba2394's Avatar
Bubba2394
I had the same problem. My car had a delayed start and sometimes wouldn't start. After looking around online I found where someone said to replace the "starter relay" so I did that and as of now it is starting instantly.The starter relay is located under the hood in the fuse box it's #9 I just bought one for $20 at orielly (if that's how you spell it) like I sai it is working like a charm now hope that helps you
