Sponsored by:
Sponsored by: CARiD
multiple misfire.. PLEASE HELP!!!!
Old Nov 17, 2012 | 04:36 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Originally Posted by charger2007
hello, i have a 2007 dodge charger. when starting my car in the morning or after it sits for a while it starts up with a shaking spell until it gets warm. the engine lightsblinks while warming up, then it stays on steady. it seems as if the gas is skipping & its putting when u start it. also if u step on the gas pedle it will cut off. in order to have a smooth ride i have to let it warm up for about 15mins prior to driving. took it to dodge & they said "multiple misfires 5&6" came up on the machine. both cylinders 5 & 6 was changed & still same issue. next they did the coil pack, INJECTORS, map sensor & throttle body. the issue is still happening. they seem to be lost on what to do next & so am i. PLEASE HELP ME
I totally understand someone spending a good deal of time on a difficult issue and replacing a part and being wrong...it happens. They should have kept it overnight and checked it on first startup in the AM. Not replace a ton of freakin' parts...then go...DUH ...we dunno??!! Who is hiring these people??
Old Nov 18, 2012 | 06:42 AM
charger2007's Avatar
charger2007
The bad part is, this week will be 2weeks they had my car & still have no clue. I'm totally lost at this point. I just want my car fixed!
Old Nov 18, 2012 | 11:40 AM
TNtech's Avatar
TNtech
If it IS a condition that can be duplicated on every cold startup, they should be able to give you some sort of answer within a few days. Since I have no way of knowing what they've done so far all I can do is speculate.
But, just judging from your explanation inititally:
DON'T erase codes because the misfire monitor will be reset and it will have to be driven in a specific manner to set it to working again before any more diagnostics are done.
Concentrate on the 2 cylinders that set single misfire codes. It may end up just being one of the 2 causing the problem. The P0300 multiple is probably only a result of serious misfires on single cylinders affecting the rest of them. P0300 is essentially a sign that something happened that caused a drop of vacuum to low levels, altered base timing or caused the PCM to overfuel.
FIRST NIGHT...Install a fuel pressure guage, run the car a few minutes then park it overnight. Observe in the AM.
If Fuel pressure hasn't dropped beyong normal, then do a cold compression test on that same first morning BEFORE running the engine.
It should go without saying (to a tech anyway) that things like Coolant temp, Cam/Crank state and Degrees between Cam/Crank signals should be looked at on the data stream.
Take a fuel sample. One possibility, you have an injector or maybe even two (hence #5 and #6 misfires) leaking down fuel pressure when it sits for long periods. The misfires on the single cylinders would be from raw fuel puddled on top of the piston on startup.
Old Nov 18, 2012 | 03:26 PM
charger2007
thak u so much.. i will copy your message & tell them to do exactly what u said. i have one mechanic saying "possible head gasket" but the other machanics are saying they dont believe that is the case since the car is NOT over heating & it is NOT leaking anti freeze. i was told they will be changing all the spark plugs on Monday. but im not too confident that will fix my problem
Old Nov 18, 2012 | 06:16 PM
TNtech's Avatar
TNtech
Well, it won't necessarily overheat on you quickly if a head gasket is leaking coolant in very small amounts into the cylinder while it sits and cools down. If your commute isn't very far every day, you may never run it long enough for it to happen. I don't know how bad you overheated it prior.
Old Nov 18, 2012 | 11:00 PM
charger2007
I really don't know much about the history of the car. The worst part of all of this is I just got it almost 2 months ago & had this issue since the 1st week. The car dealership that I purchased from is handling all the repairs but no one can seem to figure out what the problem is. The dodge dealership couldn't even diagnose it correctly. Dodge dealership asked me to bring the car back so they can call a engineer to assist them. This is all very overwhelming & extremely frustrating. Sad part is while all of this is going on, I still have to pay my car note
Old Nov 19, 2012 | 04:56 PM
DodgeCACares's Avatar
DodgeCACares
Charger,
Sorry to hear about your ongoing issues. If you are seeking additional assistance the vehicle would have to have a recent diagnosis from a Dodge dealer.
You can PM me your VIN# or you can contact the Customer Care Department for additional assistance. I've posted the phone numbers below.
Canada: 1-800-465-2001
U.S.: 1-800-992-1997
I hope this helps.
Old Nov 19, 2012 | 06:52 PM
Digger 89L's Avatar
Digger 89L
So ...was this problem ever resolved??? I have a similar P0300 issue with my 99 Caravan 3.0 litre.
Old Nov 20, 2012 | 12:17 AM
charger2007
thank u.. i sent u a PM
Old Nov 20, 2012 | 12:19 AM
charger2007
no, unfortunatelly the issue with my car is still not resolved
