Sponsored by:
Sponsored by: CARiD
2013 R/T Center Tail Light Replacment Manual?
Old Feb 17, 2016 | 11:10 PM
2therock's Avatar
2therock
Default 2013 R/T Center Tail Light Replacment Manual?
I have the cracked center tail light. I could use the pages out ot the service manual on how to get to it.
Thanks
Old Feb 19, 2016 | 06:33 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
CENTER
  1. Disconnect and isolate the battery negative cable.
  2. Remove the trim cover from the inside of the deck lid (3).
  3. Disconnect the body wire harness connector (4) from the center tail lamp (1) connector receptacle.
  4. Remove the eight nuts (2) that secure the center tail lamp to the inside of the deck lid inner panel.
  5. From the outside of the vehicle, grasp each end of the center tail lamp (1) firmly and pull straight rearward to disengage the two ball studs (2) from the two grommets (4) in the deck lid inner panel.
  6. Remove the center tail lamp unit from the deck lid opening.
Old Feb 19, 2016 | 06:36 PM
2therock's Avatar
2therock
Thanks! Here is a video I put up.
Old Feb 24, 2016 | 12:09 AM
2therock's Avatar
2therock
To wind this up please know the pins that have to be dislodged by tugging the light out do not need to be popped back in. The barb on the pins is a one way action.
Just line them up, start a few nuts to hold her up and pull her in as normal and don't crank them down hard unless you want another cracked light.
