Sponsored by:
Sponsored by: CARiD
2008 Charger - Aftermarket Stereo
Old Oct 21, 2016 | 09:30 AM
jp2code's Avatar
jp2code
Default 2008 Charger - Aftermarket Stereo
I have an aftermarket stereo on order.
The guy at Crutchfield advises me to buy this custom wiring harness:
Axxess XSVI-6522-NAV Wiring Interface: Connect a new car stereo and retain RAP and audible blind spot detection in select 2007-up Chrysler, Jeep, Mitsubishi, and Dodge models
http://www.crutchfield.com/p_1206522...Interface.html
Price: $59.99
He said I would need the adapter so that the stereo would work with the Charger's CAN-Bus wiring.
Is that correct?
This 2008 may be old, but it is the newest vehicle I have ever owned.
Looking for input from someone else who has installed an aftermarket stereo in their 2008-2010 Charger/Magnum/300.
Old Oct 21, 2016 | 02:13 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
What are you interfacing with on your car? Steering wheel controls would be enough to justify it.
The factory radios do NOT have Ignition feed. They only have a battery feed. They get their "wake-up" signal from the BUS circuits.
Old Oct 21, 2016 | 02:21 PM
jp2code's Avatar
jp2code
No steering wheel controls.
I think I just need this for the "wake-up" signal from the BUS circuitry.
Old Oct 21, 2016 | 02:33 PM
TNtech's Avatar
TNtech
Or you can just find an ignition source to tap into. I used one of the power outlets on my 2007 Ram. Be aware some cars are equipped with a movable fuse for the outlets that can make it battery feed or ignition feed. I believe slot 18 in the rear fuse box (in the trunk) is your power outlet.
Old Oct 21, 2016 | 02:42 PM
jp2code's Avatar
jp2code
Awesome! That's what I was thinking.
No, I didn't know it was plug #18, but I was thinking there was only 1 or 2 wires with the signals I needed out of that whole $60 adapter.
Thanks!
Old Oct 22, 2016 | 11:15 AM
cruzer55's Avatar
cruzer55
Go with recommended parts.It will make it plug&play instead of splicing wire.Crutchfield doesn't sell what you don't need.....................
