Sponsored by:
Sponsored by: CARiD
puzzled misfiring and smoke
Old May 12, 2018 | 11:01 AM
clong's Avatar
clong
Angry puzzled misfiring and smoke
Ok here we go i have a 2006 charger with a 5.7, a couple of days ago i drove it form one town to another and it ran normal, i get to my destination and shut it down, after 10 minutes i get back in my car and try to start it. nothing but misfires and smoke coming out my tail pipe. now i check to see if i got water in my oil and vice versa nothing the fluids are fine. changed spark plugs and in cylinder 6 and 8 the plug gap were closed and covered in oil from top to bottom. i checked compression and they both were above 155 psi. i checked the valve cover seal for the spark plug seals and they were a little hard but not bad. i have been racking my brain for 4 days.... i need help any advice you give me will be helpful.....
Old May 12, 2018 | 02:19 PM
Does it start and run yet? Check engine lite on? Any codes?
Old May 12, 2018 | 07:01 PM
clong's Avatar
clong
Just checked compression again 0psi on cylinder 8 and 30psi on cylinder 6
Old May 13, 2018 | 09:21 AM
That's not a good sign. Time to pull the valve cover, and see if anything is obvious.
Old May 13, 2018 | 05:56 PM
clong's Avatar
clong
I'm thinking pistons
Old May 15, 2018 | 08:18 AM
clong's Avatar
clong
well pulled valve cover and everything seems to be working i crank it and the valves are working.
Old May 16, 2018 | 07:56 PM
Cylinder leakdown test. (need an air compressor) I bet you are bleeding pressure between 6 and 8.
Old May 16, 2018 | 08:33 PM
clong's Avatar
clong
Look at what i found
Old May 16, 2018 | 10:22 PM
That'll do it........
Old May 17, 2018 | 11:03 AM
HemiLonestar's Avatar
HemiLonestar
At least it stayed up and didn't go say hi to the piston crown...
