Sponsored by:
Sponsored by: CARiD
Charger coolant temp almost 240!
Old Jul 3, 2018 | 02:58 PM
charger5.7's Avatar
charger5.7
Default Charger coolant temp almost 240!
Hello all, I have a 2012 charger RT . Last week i noticed a weird smell and looked at my temp gauge and seen the car was overheating so i pulled over , opened my hood and seen coolant leaking from the coolant reservoir area. The shop i take my car to said one of the hoses was cold and should be hot and that i needed a new thermostat and see what happens from there. 3 days later while sitting in traffic with the AC on i noticed my car was running a little hot. The needle was half way inbetween the middle and the next line after the middle . So i checked my coolant temp and it said i was nearing about 238 degrees. Now my car only starts to overheat when the AC is on. When i turn it off it gradually goes down and when i turn it on it gradually goes up. What is this a sign of? Figured id post here to ask and get an idea before i take it to the shop and assume that everything they tell me is the truth
Old Jul 4, 2018 | 12:56 PM
Are you low on coolant? Do you still have a leak?
Old Jul 5, 2018 | 10:05 AM
charger5.7's Avatar
charger5.7
No i do not have a leak anymore and im not low on coolant. Sorry for the late response
Old Jul 5, 2018 | 05:22 PM
Maybe an air pocket left in the system yet. Not sure what the burp procedure on the Chargers is though.
Old Apr 15, 2024 | 03:16 AM
christiankh's Avatar
christiankh
Default cooling fan check
hello. i know the reply is late but i had a similar issue. it was the primary fan that was not working and all the load was on the secondary one that eventually couldn't take it and broke down. what happened ?
