Sponsored by:
Sponsored by: CARiD
2010 charger not charging help please
Old Nov 5, 2021 | 06:43 PM
charliebrown122174@gmail.com's Avatar
Default 2010 charger not charging help please
I have 2010 charger my battery light was coming home likely here and there and now it started burning all the time I changed out my alternator and battery from advance Auto parts and my battery light is still staying on my car is not charging I disconnect the cable the engine shuts off it drains pretty quickly when connected the battery I don't understand what else to do can someone please maybe give me a little advice on how to fix the problem I cannot afford to bring it to a mechanic at the time so I am the mechanic however I do have all the test what needed to be tested I think is there an inline fuse on this car or maybe some other thing that charges the battery
Old Nov 6, 2021 | 11:01 AM
Pull the alternator, and have it tested separate from the car. If it tests good, voltage regulator is bad. Unfortunately, the VR is part of the PCM....
