Sponsored by:
Sponsored by: CARiD
P0153 and P0133 cat delete
Old Feb 26, 2022 | 03:30 AM
seroralbayati's Avatar
seroralbayati
Angry P0153 and P0133 cat delete
hi guys
i have a charger rt plus 2015 stock
i bought the car used and it had a cat delete . i had p420 codes about the catalyst not working properly so a friend of mine advised to use a o2 spacer
after installing the o2 spacer on both sides . the code relating to the catalyst converter is gone but now i have p2096 code sayign the post catalyst fuel trim lean
if the code stays for a few days the p171 and code p131 pops saying the fuel trim lean and the o2 sensor on bank 1 s1 has a slow response .
i checked for vacuum leaks and my vacuum valve was bad so i replaced it but still getting the p2096 code
i checked for other leaks and nothing is showing on the vapor test
i checked for the fuel injectors and the fuel pump they were fine
last thing i did i replaced the bank 1 s2 sensor with bank 2 s2 sensor now m getting p153 code saying the bank 2 s1 sensor slow response
what are your thoughts ? can the s2 effect s1 readings on the same bank ? should tune the car will that work ? cuz my mechanic said i can only tune the s2 sensor i cant play with s1 cuz s1 means you have a problem not related to the cat
i really need your help guys m really sick of the cel
Old Feb 26, 2022 | 08:47 AM
Reinstall converters.
Old Feb 26, 2022 | 09:00 AM
If moving the sensor moved the code as well, change the sensor. (NTK or Denso sensors only please.) Get that fixed first, clear codes, and see if anything comes back.
