Sponsored by:
Sponsored by: CARiD
dodge charger replacing tire size
Old Jan 31, 2023 | 05:01 AM
Ali Mearaj's Avatar
Ali Mearaj
Default dodge charger replacing tire size
hi dears,
need ur help .. i have dodge charger v6 SE am planning to change my tire size from the original size ( 235/55R18 ) to ( 245/50R18 )
Need ur advise please
thanks
Old Jan 31, 2023 | 08:55 AM
What kind of advice?
Here is the difference.
Old Jan 31, 2023 | 09:17 AM
Ali Mearaj's Avatar
Ali Mearaj
thanks bro
just i want to ask if someone try it and if there is effect on the car like vibration, check engine or anything alse am thinking to buy Michelin PS4 tires,
and do u advise me to buy K&N filter or just stick with the original
Old Jan 31, 2023 | 01:27 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Keep the same tire height. That's what throws things off. A 245/55 would be close enough in diameter (if available). Otherwise if you have a proper tire balance performed then you shouldn't get any vibration.
Old Feb 1, 2023 | 12:19 AM
Ali Mearaj's Avatar
Ali Mearaj
yes but there is no 245/55R18 tires not available, i want proformance tire which is the close only is 245/50R18
Old Feb 1, 2023 | 07:32 AM
Originally Posted by Ali Mearaj
thanks bro
If they are properly balanced, they will not cause vibrations nor cause a check engine light. Only thing it will affect is speedometer if you go to a different size. K&N drop in is a good investment. Just realize it needs to be cleaned periodically as opposed to a paper filter.
Old Feb 1, 2023 | 08:14 AM
Ali Mearaj's Avatar
Ali Mearaj
Thumbs up
thanks for ur help bro
