Sponsored by:
Sponsored by: CARiD
Remote start is wonky
Old Mar 19, 2024 | 07:59 PM
johnnyrocket5363's Avatar
johnnyrocket5363
Default Remote start is wonky
My Charger has been weird with the remote start for a while. Around once out of four times, the car will start, run for a few seconds and shut down. Remote starting again works, and as of now the second time stays running. So in the morning, I remote start, wait a few seconds and look out the window. If the car turned off, I remote start again and all is well. There are no check engine lights and as far as I know all systems are running well. Oil pressure is great at idle, volts are at 14.2 as soon as the gauge loads. I don't know if it's possible to datalog, or if there are ever any flags set by the system when remote start doesn't work. Any ideas? Thanks!
Old Mar 19, 2024 | 08:03 PM
How long does it take for oil pressure to come up from a cold start? No idea if the computer even cares.... but, it's a thought.
Old Mar 19, 2024 | 08:07 PM
johnnyrocket5363
I'm honestly not sure. It's up as soon as the gauge loads in the dash. I think it has a high volume pump from the previous owner.
Old Mar 20, 2024 | 08:52 AM
That is gonna be a fun one to track down.
Old Mar 22, 2024 | 11:15 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
After every few remote starts you have to start it manually; this is a software thing that continues to this day.
Old Mar 19, 2026 | 06:54 AM
johnnyrocket5363
You're not kidding. Not to necro my own post but I'm still trying to track it down. The only other piece of intel is that occasionally, after remote starting and remote opening the trunk the alarm will go off. No idea why. I saved the AlfaOBD logs and can't see anything glaringly obvious. Kinda tempted to replace the trunk open sensor to see if it helps but hate just slinging parts.
