Sponsored by:
Sponsored by: CARiD
Engine Oil Cooler leaking Coolant
Old Mar 31, 2024 | 06:51 PM
Jason M's Avatar
Jason M
Default Engine Oil Cooler leaking Coolant
I’ve replaced my original OEM cooler with a Dorman Aluminum.
Everything
went in smooth, torqued to spec; However, when refilling my coolant reservoir I noticed coolant leaking from the top of the engine cooler, not the o rings, nothing in the valley.
in addition, I have coolant coming out of my oil pan. I’m assuming the coolant is mixing into my oil lines through the engine cooler.
Any ideas on what’s causing this?
Old Mar 31, 2024 | 08:57 PM
Usually, that's a sign of a bad cooler........ or a failed gasket in the cooler.
