Sponsored by:
Sponsored by: CARiD
Hood strut install?
Old Jun 26, 2006 | 04:03 AM
  #21
Dartman69's Avatar
Dartman69
Default RE: Hood strut install?
How strange! My Charger came factory-equipped with hood struts. Is this whole "hood-prop" deal a USA exclusive problem (as I am from Canada)?
Old Aug 2, 2007 | 10:21 PM
  #22
07RTRTCharger's Avatar
07RTRTCharger
Default Just did it myself!!!
I just installed the kit myself. I used a 8mm 1.25 tap but I don't think it's absolutely necessary. I think there's a greater risk of scratching the fender with the tap handle than it's worth. I started the tap on both sides just to give the stud a place to start. The screwed right in without much fuss. I used a 13mm box end wrench. No big deal. Once the stud is in the strut was a piece of cake. The bottom end is forked and grabs around the ball stud from underneath. Then a lock slides down over the ball. In the top end, The drivers side lines up pretty close. Use a small flat head screwdriver to pry out on the spring lock. There's a slot in the back for this purpose. You don't need to pull too far. Just enough for the ball to easily slide into the hole. Release the spring clip and you're done with the drivers side. The passenger side took an assistant. My son held up the hood as I put the strut rod down. The passenger side went on just as easy. It really is a 10 minute job.
Old Aug 31, 2007 | 07:05 PM
  #23
TopBanana2953's Avatar
TopBanana2953
Default RE: Just did it myself!!!
I agree it is an easy mod. It always bugged me when I saw the prop rod on a HEMI come on....That just isn't American I did the mod without the tap however. I asked this same question a few months back and someone else mentioned they saw it done w/o the tap. Just thought you should know.
Old Aug 31, 2007 | 09:22 PM
  #24
MangoInTX's Avatar
MangoInTX
Charger Moderator
Cool, here are the part number for the hood struts: 5065278AD & 5065279AD
Let me know if you have extrasI still use the prop-brace.
Old Sep 3, 2007 | 07:12 PM
  #25
rucci1's Avatar
rucci1
Hey guys, I put them on my r/t and love them. They are actually on a fiberglass hood I had installed that I bought from rksports. I love them... get em.. you won't regret them...
Old Dec 13, 2009 | 12:37 PM
  #26
Dodge-Magnum-hsv's Avatar
Dodge-Magnum-hsv
Smile
Originally Posted by Lateral-G
Did '05 Chargers have the struts? I had an 05' Magnum and it had the prop rod. AFAIK struts were never issued on any year Magnum or Charger from the factory.
-G-
Some people have stated that a 2005 Dodge Magnum was NEVER built with hood struts. I still own a 2005 Dodge Magnum I bought in the fall of 2004. It has hood struts that failed 11/09. (Background: This fully equipped SXT Inferno Red paint, light gray leather interior, Magnum model was specifically made for "Dodge Premier Night".)
Old Feb 2, 2010 | 04:19 AM
  #27
Midnight Blue's Avatar
Midnight Blue
Sounds about right, had to replace the trunk struts on the wife's '03 300m a couple of years ago because they were getting soft. She stashes her laptop and purse in the trunk when she goes to work so the trunk gets opened twice a day. The hood struts on that car are still good though. Also it's been 4 years since I did the conversion on my Charger (check the 2nd or 3rd message from the beginning of this thread) and they are still going strong with no hood warpage.
