Sponsored by:
Sponsored by: CARiD
LOW TIRE SENSOR LIGHT ON?????
Old Jan 19, 2007 | 04:09 PM
RT 2 NV's Avatar
RT 2 NV
Default LOW TIRE SENSOR LIGHT ON?????
my low tire sensor came on. i checked all of the tires all are at 28pounds? they have not been touched sence the day i got the car. i have 3000 miles on it and have had it about 5 mounths. what is everyone running the tire pressure at? what should i do. im due for the oil so i might just take it in? thanks in advance.
Old Jan 19, 2007 | 04:45 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: LOW TIRE SENSOR LIGHT ON?????
I run mine a bit high @ 35
<edit> Check out the sidewall, I believe they'll say 31 psi, pump those puppies up a little.
Old Jan 21, 2007 | 02:13 AM
baldyloxs's Avatar
baldyloxs
Mine were at 28 and the light came on .
Old Jan 21, 2007 | 08:42 AM
Wallyworld Ranger's Avatar
Wallyworld Ranger
Just out of curiosity, has the temperature gone below freezing where you are? Here in the Northeast, the temps have started todrop tofreezing or just belowat night. When I go to work at 8 pm it's above freezing and the low pressure light is off. When I leave workat 4 am to come home it's freezing or below and the light is on.Once I'm on the highway for a few miles it seems the tireswarm up and expand and the light goes out. The same thing happens with our Chevy Impotent (ooops I mean Impala) patrol cars that are equipped with a tire sensor system when they are out of rotation for a shift. The whole heat expands/cold contracts thing.
Old Jan 21, 2007 | 12:19 PM
74scamp's Avatar
74scamp
Also, if your at a high altitude, that will affect it also. Higher altitude translates into having to pump them up a bit (29-30). At least, that's what my dealer said. However, I've changed tires (Goodyear's Assurance) and they don't seem to be affected as much. At least the light doesn't come on at 28lbs, and I'm at a mile high and it's been unusually cold this year.
Hope this helps.
dave
Old Jan 21, 2007 | 06:48 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Off subject, sorry.... What's the weather like there Dave? I'm going to Boulder late next week and would like to know, first hand, what to expect.
Old Jan 21, 2007 | 11:57 PM
74scamp's Avatar
74scamp
The weather has been cold. We had another small snow storm blow through yesterday - nothing like what we had just before the beginning of the year. Could get more tonight, but my guess is probably not. If we do, it will probably be very light. I think the high temps this week are supposed to be low to mid 30s.
Now, Boulder could be a different story. Are you driving or flying?
dave
Old Jan 22, 2007 | 12:58 PM
Trina_Syn's Avatar
Trina_Syn
I was always told 32 pounds pressure was average. I've had my car the same amount of time but no light as of yet.
Old Jan 22, 2007 | 02:34 PM
RT 2 NV's Avatar
RT 2 NV
yes im in cold wisconsin and finally got below 32 this last week. that my be it. ill watch it and see when it harms up. im going in for the oil i will have the double check thou. thanks again.
