Sponsored by:
Sponsored by: CARiD
After market suspension
Old Feb 1, 2007 | 05:20 PM
74scamp's Avatar
74scamp
Default After market suspension
Who here has changed the springs out and, my main question, did you compare the new with the old? Did it appear - or maybe someone knows - that the new springs were wound differently, i.e., more progressively, etc.?
I'm thinking of getting Eibachs or something similar. My main goal is not the lowering of the car, but to get better controlledsuspension movement. Mine feels pretty stiff in the beginning of the wheel travel, then seems to get softer the further the suspension iscompressed.
dave
Old Feb 1, 2007 | 11:42 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: After market suspension
Ok, so is a bit lower like an inch,ok?
From threads I'veseen you will get rid of the "boat" ride and will drop about 1" depending on manufacture.
Look into:
Eibach
Pedders
Gold Line
Old Feb 2, 2007 | 12:17 AM
74scamp's Avatar
74scamp
Yeah, that 1 inch or so lower is fine - that would bring it down to about what the Daytonas are, right? Aren't they about an inch or so lower than a standard R/T? But what I'm trying to figure out is are the after market springs a better progressive wind than the factory units. I suppose some folks might say replace the shocks and struts, but money is now a factor, i.e., the lack of it to completely change out everything. So, I need to try and find out the answer to my question before spending the money . I don't want the ride to suffer, just more controlled and perhaps better able to "soak" up the small, expansion joint type bumps. Maybe I'm just asking for too much?
dave
Old Feb 2, 2007 | 11:03 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
There are mixed feelings out there about the struts and shocks. Some say the stock ones will blow others say the stock ones are fine. I have'tread about someone blowing the stock strut/shocks out. On the flip side there isn't adefinitive answer yet [&:]
Old Feb 2, 2007 | 11:21 AM
74scamp's Avatar
74scamp
I've had correspondence with the folks at Pedders, and they agree with my assessment that the shocks, struts, and springs on the LX platform are under sprung and under damped. He said they have coils that will lower it about an inch, and they have some new, gas shocks and struts that they will be introducing at SEMA that will further help it. I've asked for some more info and we'll see what they have to say. I'm going to contact Eibach and, ummm, the other one you told me about
dave
Old Feb 2, 2007 | 12:10 PM
BigBananna3796of4000's Avatar
Can you lower a Daytona w/ springs? Dont he rear controlled shock pose a problem?
This year I want to buy 20's for the car and want it to sit lower, like the SRT's.
Old Feb 2, 2007 | 12:53 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
The Daytona or the ones with the tow package can't be lowered in back w/just springs. The self leveling Nivomats have to be taken off.
Old Feb 2, 2007 | 01:05 PM
You took off the nivomats right?
What did it do to the ride?
Old Feb 2, 2007 | 02:27 PM
74scamp's Avatar
74scamp
I have an R/T, not a Daytona. I suspect that the Daytona's suspension is much better than the standard R/Ts to start with. I think the Daytona is also about an inch or so lower to start with. But, yes, I can lower my R/T with just a change of springs. But it's not so much the lowering I'm looking for as it is a better, more compliant ride.
dave
Old Feb 2, 2007 | 03:58 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Yes, the Nivomats are gone. The ride is stiffer, you will loose the cushy ride going this way but you can feel the road much better.
If you order the R/T w/towing pkg you also have the Nivomats in the rear.
