1960 Dodge Dart Pheonix
Old Sep 21, 2009 | 11:02 PM
johnny pheonix's Avatar
johnny pheonix
Wink 1960 Dodge Dart Pheonix
Just picked up a 1960 Dodge Dart phoenix. It seems to hang low in the back...more so the passenger side.Cant see anything broke...Can you use air shocks to lift these?? Doesn't run right now but the engine seems free, Want to empty the old gas and fill with new gas , No brakes but will investigate that also. ANYBODY got any advise on these?? Don't know where to start!!!
Old Sep 22, 2009 | 07:27 PM
rare aries's Avatar
rare aries
Keeper of the Ks
I had similar sagging problem with my 5th Ave, when I put new shocks in the rear I installed a pair of coil over shocks, it now sits nice and level.
I need you to clarify the running situation, when you say its not running right now, do mean you its not running at all or it runs but not correctly.
With the brakes I'm assuming it has drums all around, start by pulling all the drums off and check the wheel cylinders for leakage, then examine all the brake lines.
Old Sep 23, 2009 | 01:50 AM
johnny pheonix
car didn't run in 20 years. Have to get keys made. popped out the ignition switch today..to give to locksmith in the AM. I changed oil/filter plugs/wires etc. put in a fresh battery...just waiting on the keys. Hope she goes without any knocks>> Tempted to hot wire it, but it started getting dark out...so I decided to wait for keys. Talked to a couple guys about the coil overs vs airshocks. This thing is a very long boat so air shocks will probably be the best way to go to guarantee the best LIFT.. THANKS FOR YOUR HELP!!! Always good to hear from you dodge fans!!
Old Sep 23, 2009 | 02:01 AM
johnny pheonix
Want to drain the gas out the tank. See a round metal plug of some sort toward the rear of the tank. Anybody know how these come out? Plug has a hole in the center. Can see if it's a hex key hole or just a round hole. ( i'm so blind ) Any help always appreciated !!!
Old Sep 23, 2009 | 07:36 PM
rare aries's Avatar
rare aries
Keeper of the Ks
I had a 64 Rambler years ago with the same type of plug, I used an e-z out to remove it, and replaced it with a bolt the same size with a hex head and rubber gasket.
Old Sep 25, 2009 | 10:39 PM
johnny pheonix
GREAT IDEA!! thanks!
Old Oct 1, 2009 | 02:13 AM
johnny pheonix
Default 1960 dart steering wheel
I need a 1960 dart steering wheel bad. Mine is disintegrated!! Anybody know where I could find one?? Any old dodge junkyards you know of ??
Old Oct 1, 2009 | 02:16 AM
johnny pheonix
Default 1960 dart trans leak.
Got my 1960 dart up and running. sounds pretty good...unfortunately, trans leaks in between motor and trans area. Would this be the front trans seal??
Old Oct 1, 2009 | 10:00 AM
rare aries's Avatar
rare aries
Keeper of the Ks
It could be your rear main seal or the pump seal on the tranny.
Old Oct 3, 2009 | 10:32 PM
charon187's Avatar
charon187
in a '60 your leaf springs are shot. you need to get them rearched should run around $400 as far as used mopar wreckers i love these guys (no i dont work for them) the just rock i have bough many parts and one car off em lol. san diego area
Cheers!
Sweetwater Auto Wrecking
6301 Quarry Rd
Spring Valley, CA 91977
(619) 475-1005
