1975 D100 Transmission Question
Old 09-22-2011, 09:41 PM
walkerone's Avatar
walkerone
walkerone is offline
Default 1975 D100 Transmission Question
Hello first time doing this forum thing,
I need some help with a transmission question. I have a 1975 dodge D100 truck, 318 v8, 3 on the tree best thing its got is PS. She has been good to me but the 3 speed is screaming in all gears and is becoming hard to shift. I worry its just a mater of time before it dies out on me. I was looking for a replacement to swap in as I don’t have tons of money. Was looking to find some information on what the transmission in my tuck is and if there are any upgraded types of manuals that are more or less just a easy swap from the stock 3 speed.
Thanks
Old 09-25-2011, 04:13 PM
Wombat Ranger's Avatar
Wombat Ranger
Wombat Ranger is offline
Any swap from this era is fairly simple. If i was you, I'd find a 4 spd truck, cut a hole in the floor, and you will never have to replace it again. Those granny gear 4 speed np435's are bulletproof.
Old 09-27-2011, 06:29 PM
walkerone's Avatar
walkerone
OK well thats good news ....Will need a new bell housing , flywheel clutch and drive shaft? I found a donner truck with the 12 bolt I need. It also has a 4 speed but I get charged for each part so don't want to take anything I don't need.
thanks again
Old 12-09-2011, 06:23 PM
moe7404's Avatar
moe7404
moe7404 is offline
check out converting to a 727 automatic trans. if you are not in steep hills, you will like the automatic. but a few thinks to change, like a cooler for the trans
Old 12-09-2011, 06:41 PM
Wombat Ranger
Hey somehow I ignored your response! sorry man, hopefully the swap went smoothly. If you have any more questions I will do my best to answer them... sooner then in 3 months time
Quick Reply: 1975 D100 Transmission Question
