Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Speedometer does not function any more
Old Jul 10, 2007 | 08:08 AM
SAINT_JOCELYN's Avatar
SAINT_JOCELYN
Default Speedometer does not function any more
Hello,
I have a Dokota 1999, 3.9. This morning,the light “ABS” and the light of brake hand lit. Moreover, the speedometer stopped functioning. All that at the same time. Somebody has to you it an idea of the problem and solution which goes with.
thanks
Old Jul 10, 2007 | 10:53 AM
Billiam's Avatar
Billiam
Default RE: Speedometer does not function any more
Check the conections on the cluster. If they are getting a good connection it could be a bad cluster or a speed sensor.
Old Jul 11, 2007 | 08:08 AM
SAINT_JOCELYN
Unfortunately it is not the speed sensor of the transmission nor the connection. I have to check wire and I have to install new a speedsensor and the problem is always. Do you have another idea? [/align][/align]Thanks for your help.[/align]
Old Jul 13, 2007 | 11:03 PM
master tech's Avatar
master tech
Site Moderator & Tech
You could have a broken wire going to the speed sensor. I see it all the time with neons.
Old Jul 18, 2007 | 10:36 AM
SAINT_JOCELYN
I found the problem, I believed that the defective speed sensor was on the tranny. it is not the case, the speedometer takes its signal on ABS sensor on the différenciel, it was him which was deffectueux. [/align]
