damn ricers
ORIGINAL: wink2873
dont screw around with nitrous, cam the 5.9 and be done with it. With an aggressive cam you'll blow away pretty much any ricer out there.
if you put good cams in it and leave stock pistons and stock rods your liable to throw a rod or burn a hole through your piston, putting in cams is a huge jump towards a race motor, if you go that far you might just want to ditch the EFI and put a carb on that bad boy
Guest
Posts: n/a
I dont know about going CARB, but doing a good fuel system is vital to more power.
A higher flowing fuel pump and a nice ignition are a start.
I dont agree that you HAVE to put in better pistons/rods... but a little more compression couldnt hurt.
And the piece of mind that your motor wont go boom is another good reason to think about it.
rods and pistons are your friend when it comes to BIG power.
